Are you running ATS 7x15 on your 914?, What size and type of tires are you running? |
draganc |
Aug 29 2011, 11:47 AM
Senior Member Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
Hi,
I have a set of ATS 7x15 with 30mm offset and was wondring if anyonw is using the same rims on a narrow body? Any information/pictures are apriciated. Thanks, Dragan |
campbellcj |
Aug 29 2011, 09:36 PM
Hi, I have a set of ATS 7x15 with 30mm offset and was wondring if anyonw is using the same rims on a narrow body? Any information/pictures are apriciated. Thanks, Dragan Are you talking about the Cookie Cutter wheels (5-lug), or some other type? I do not recall the offset on cookies but many folks including me have used them successfully. I used 205/45 Kumho V-somethings as I recall, probably V700 Victoracers. It's been a while. |
ConeDodger |
Aug 29 2011, 11:44 PM
Apex killer! Group: Members Posts: 23,586 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
205 50 15 is pretty much the limit. Hoosiers in that size will not work. Your rear fenders could need rolling.
draganc |
Aug 30 2011, 08:31 PM
Nope no cookie cutters.
Here a pic that I have found online: |
draganc |
Aug 30 2011, 08:33 PM
one more. I'm playing with the thought to have them painted fake mag/gold:
jimkelly |
Aug 30 2011, 08:39 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
those are probably not 7" wide - 5.5" i think.
underthetire |
Aug 30 2011, 09:42 PM
I'm running 16x7 late offset dials if that helps. 205/50 with 1 1/4 spacer. It's mighty close in the rear on a narrow body.
racerbvd |
Aug 30 2011, 10:39 PM
Advanced Member Group: Members Posts: 2,368 Joined: 3-February 03 From: Sunny FL. Member No.: 226 Region Association: None |
Here is what 7s look like..
bernbomb914 |
Aug 31 2011, 06:37 PM
one of the oldest Farts on this board Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 |
I run 205x15 on 6" width and thet barely clear
Aug 31 2011, 07:17 PM
Its interesting , but 6 inch wheels fit worse than 7 inch wheels with 205/50's
The 7 inch wheels allow the sidewall to be more vertical. The rubbin gon the rear can be cured with a little rolling of the lower fender lip. The front wheels will rub on full lock on the inside...but spacers can cure that. Rich |
draganc |
Sep 1 2011, 02:48 PM
shuie |
Sep 1 2011, 04:20 PM
Member Group: Members Posts: 352 Joined: 17-May 04 From: baton rouge, la Member No.: 2,075 |
That car has 205/50/15 Hoosiers on all 4. The fenders are pulled and rolled. The car is slightly modified (IMG:style_emoticons/default/wink.gif)
These are very cool wheels. Surprsingly lightweight. |
RON S. |
Sep 2 2011, 07:31 AM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
They are nice looking wheels.
i have 5 of these 7''rs sitting in my shed, that were on my 914/6 when I first bought it back in the 90's. A 914 has to have flares, and 5 lugs to make these work. Ron Attached image(s) |
shuie |
Sep 2 2011, 03:07 PM
Here's a 7x15 with the 4x130mm lug pattern
(IMG:https://lh6.googleusercontent.com/-BBu81t_S620/TmFFGv6iTcI/AAAAAAAAJ-4/6yTRw0pOUHA/s640/ATS.jpg) |
tavoman27 |
Sep 3 2011, 12:32 AM
Member Group: Members Posts: 96 Joined: 13-January 10 From: Fontana Member No.: 11,226 Region Association: Southern California |
Hi, I have a set of ATS 7x15 with 30mm offset and was wondring if anyonw is using the same rims on a narrow body? Any information/pictures are apriciated. Thanks, Dragan 205-50 is all you can fit on a narrow body, the rear lips need to be rolled a tiny bit... 944 front 8x16 fuchs work great on the front but nothing bigger than 7 can be used on the rear for a narrow body 914. |
draganc |
Sep 5 2011, 01:06 AM
Here's a 7x15 with the 4x130mm lug pattern (IMG:https://lh6.googleusercontent.com/-BBu81t_S620/TmFFGv6iTcI/AAAAAAAAJ-4/6yTRw0pOUHA/s640/ATS.jpg) Yeap, that's what I have :-) |
Lo-Fi Version | Time is now: 15th May 2024 - 04:23 AM |
