74 1.8 L-Jet Issue |
SteveL |
Jul 12 2004, 12:01 PM
Senior Member Group: Members Posts: 658 Joined: 7-August 03 From: Andover, MN Member No.: 991 Region Association: None |
I have a 74 1.8 with L-Jet. Driving down the road, once in a while it sto firing for a moment, then cough and be fine for a second, then do it again - usually around 3000-34000 RPM. If I don't move the throttle, it will stay "dead", if I back off the throttle or floor it, that is when it seems to come back to life. No idiot lights come on.
Here's what I've already done: All new vacuum hoses New aux air regulator Cold start injector tested plugged in and unplugged New cap, rotor, plugs, wires New gaskets for oil filler New head temp sensor (IMG:style_emoticons/default/blink.gif) Any ideas? I'm thinking maybe: 1. Fuel pump 2. Throttle position sensor 3. Air flow meter Thanks! Steve |
scotty |
Jul 12 2004, 12:17 PM
The Fun Never Stops Group: Members Posts: 773 Joined: 20-May 03 From: Portland. Oregon (SW) Member No.: 718 Region Association: None |
QUOTE usually around 3000-34000 RPM (IMG:style_emoticons/default/ohmy.gif) Seriously, check the electrical connectors at the throttle switch and air flow box. Can you tell if it's flooding out? |
SteveL |
Jul 12 2004, 12:20 PM
I have unplugged and reconnected both of those connectors, not that it can't still be one of them. The connection at the air flow meter might be suspect, but then playing with the throttle wouldn't make a difference, right?
It does feel like it is flooding out. |
Jul 12 2004, 12:35 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
head temp sensor is loose or wire brittle or contacts corroded ...
check your ground too while you're in there, especially the block that sits on top of the case near the intake/throttle body. Andy |
ClayPerrine |
Jul 12 2004, 01:42 PM
Life's been good to me so far..... Group: Admin Posts: 15,518 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
The throttle switch on an L-Jet system would not have any effect on part throttle problems. It only has 2 contacts, one that is closed at idle, and one that is closed at wide open throttle.
The first thing that I would check is the grounds under the intake plenum. Then make sure that you have NO vacuum leaks, Including the oil cap seals. Unlike a D-jet, which will idle fast when there a vacuum lean, the L-jet will run lean at all ranges. This inculdes the large black tube betweent the throttle body and the air flow meter. Check in all the folds for splits. The air flow meter is mounted to the body and the tube constantly flexes as the engine torques up. They suffer really badly with broken motor mounts. Also make sure that the head temp sensor is working and solidly grounded, and check the dropping resistors for breaks in the wires on them. The last thing I would fool with would be the air flow meter. It should not need recalibrating. But if your car ever backfired, it can cause the flap inside the air flow meter to warp and stick at times. Hope that helps. Clay Perrine 74 914 1.8L (Parade P3 AX class winner! ) 73 914 2.4L MFI Six (In process of reassembly) "It is better to wear out than to rust out." (IMG:style_emoticons/default/type.gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 02:29 AM |
