Question about plumbing Webers |
Porsche Rescue |
Apr 24 2003, 09:26 AM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
I am installing a 2.0 engine with Weber 40's fitted. This is my first experience with a carbed engine. It came to me with the fuel block/pressure regulator pictured below. It was marketed or made by PMO. It has a broken fuel barb and I need to repair or replace it.
My question: Is this a good system? It is "1 in/4 out", 2 out to carbs, 1 out to gauge, 1 out to tank. The return to the tank regulates the pressure with a hose clamp that restricts the outflow to the tank. Should I fix or replace this or is there a better system. Haven't checked to see what pump I have yet. It has been moved up front. Haven't talked to PMO yet either. Thanks for any advice. Expect more questions in the next week or two as the install proceeds (wiring? breather hoses?). Stay tuned. Attached image(s) |
rhodyguy |
Apr 24 2003, 04:41 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,080 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
jim you can simply close off the return line by plugging it at the lower rear fire wall. or do it at the tank bottom and use of new short piece line. what did p use in the early carbed 4 cly engines? a return line? what sort of outlet in the bottom of the tank. to my mind, if the line failed at the reducing clamp, it would be line choking the spray nozzle down on a garden hose that's wide open. fine spray, goes further. i could never trust that setup thats on your ride jim.
kevin |
Lo-Fi Version | Time is now: 19th May 2024 - 03:54 PM |
