Question about plumbing Webers |
Porsche Rescue |
Apr 24 2003, 09:26 AM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
I am installing a 2.0 engine with Weber 40's fitted. This is my first experience with a carbed engine. It came to me with the fuel block/pressure regulator pictured below. It was marketed or made by PMO. It has a broken fuel barb and I need to repair or replace it.
My question: Is this a good system? It is "1 in/4 out", 2 out to carbs, 1 out to gauge, 1 out to tank. The return to the tank regulates the pressure with a hose clamp that restricts the outflow to the tank. Should I fix or replace this or is there a better system. Haven't checked to see what pump I have yet. It has been moved up front. Haven't talked to PMO yet either. Thanks for any advice. Expect more questions in the next week or two as the install proceeds (wiring? breather hoses?). Stay tuned. Attached image(s) |
campbellcj |
Apr 24 2003, 09:49 PM
I can't Re Member Group: Members Posts: 4,545 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
FWIW this is the "possibly temporary" pump & filter setup on my -6 conversion. It may either be redone or moved, depending on the fuel cell setup I decide on (rectangular on the trunk floor vs. bladder in the stock tank.) This is a stock 914-6 fuel pump (I think).
I can't think why you'd need a pressure regulator if you have the correct pressure/volume pump? Attached image(s) |
Lo-Fi Version | Time is now: 19th May 2024 - 07:56 PM |
