Question about plumbing Webers |
Porsche Rescue |
Apr 24 2003, 09:26 AM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
I am installing a 2.0 engine with Weber 40's fitted. This is my first experience with a carbed engine. It came to me with the fuel block/pressure regulator pictured below. It was marketed or made by PMO. It has a broken fuel barb and I need to repair or replace it.
My question: Is this a good system? It is "1 in/4 out", 2 out to carbs, 1 out to gauge, 1 out to tank. The return to the tank regulates the pressure with a hose clamp that restricts the outflow to the tank. Should I fix or replace this or is there a better system. Haven't checked to see what pump I have yet. It has been moved up front. Haven't talked to PMO yet either. Thanks for any advice. Expect more questions in the next week or two as the install proceeds (wiring? breather hoses?). Stay tuned. Attached image(s) |
Brad Roberts |
Apr 24 2003, 04:32 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Basically they bleed off pressure not used. The stock system builds pressure against the regulator and "dumps off" what it doesnt need.
Jim's setup is doing the same thing. Jim: Here is what I would do: Plug all the lines coming out of the block and turn the pump on for 4-5 seconds. Let the gauge show a reading and release the return line into a gas can. You'll know real quick whether or not you have a high pressure pump. BE CAREFUL. You can use your finger over the return hose to build pressure against. Make sure you have somebody in the car with the key on/off. It will only take a few seconds. Use a long long hose to reach the can if the gauge/return line setup is still in the car. The guy who burnt his wifes car to the ground.. had a fuel line rupture because the pump built up too much pressure in front of the regulator. It burst a line near the fuel pump under the car while running down the freeway. FLAME ON. B |
Lo-Fi Version | Time is now: 8th May 2024 - 04:24 AM |
