Question about plumbing Webers |
Porsche Rescue |
Apr 24 2003, 09:26 AM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
I am installing a 2.0 engine with Weber 40's fitted. This is my first experience with a carbed engine. It came to me with the fuel block/pressure regulator pictured below. It was marketed or made by PMO. It has a broken fuel barb and I need to repair or replace it.
My question: Is this a good system? It is "1 in/4 out", 2 out to carbs, 1 out to gauge, 1 out to tank. The return to the tank regulates the pressure with a hose clamp that restricts the outflow to the tank. Should I fix or replace this or is there a better system. Haven't checked to see what pump I have yet. It has been moved up front. Haven't talked to PMO yet either. Thanks for any advice. Expect more questions in the next week or two as the install proceeds (wiring? breather hoses?). Stay tuned. Attached image(s) |
Porsche Rescue |
Apr 24 2003, 05:09 PM
Brad, if I understand correctly, the stock pump is not shooting out 30+ psi fuel but rather the stock FI pressure regulator is "plugging things up" so as to create high psi. If I hear you correctly, I could continue to use the PMO set up, especially if I use high pressure hose and make sure the gauge is reading 3.5 psi (PMO says 4 to 5 and turn up to 6-7 at the track, but maybe that is for a six).
Lo-Fi Version | Time is now: 8th May 2024 - 03:52 PM |
