Question about plumbing Webers |
Porsche Rescue |
Apr 24 2003, 09:26 AM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
I am installing a 2.0 engine with Weber 40's fitted. This is my first experience with a carbed engine. It came to me with the fuel block/pressure regulator pictured below. It was marketed or made by PMO. It has a broken fuel barb and I need to repair or replace it.
My question: Is this a good system? It is "1 in/4 out", 2 out to carbs, 1 out to gauge, 1 out to tank. The return to the tank regulates the pressure with a hose clamp that restricts the outflow to the tank. Should I fix or replace this or is there a better system. Haven't checked to see what pump I have yet. It has been moved up front. Haven't talked to PMO yet either. Thanks for any advice. Expect more questions in the next week or two as the install proceeds (wiring? breather hoses?). Stay tuned. Attached image(s) |
Porsche Rescue |
Apr 24 2003, 05:24 PM
As always, you are a great resource Brad. I am 99% sure my pump is the stock FI pump. I intend to replace the broken hose barb and plumb things as they were. If the gauge reads 3.5-6 (and if fuel is not leaking or blowing by the needles) I'll leave it alone. I'll report when I get the engine in and running. I'm sure I'll have a few more questions for this board before I light the fire (no pun intended).
Kevin, thanks to you as well. I'll be in touch soon for a repeat on your instructions regarding a breather box. I found one at a VW shop as you suggested, just need a reminder on how to hook it up. |
Lo-Fi Version | Time is now: 8th May 2024 - 12:00 PM |
