Question about plumbing Webers |
Porsche Rescue |
Apr 24 2003, 09:26 AM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
I am installing a 2.0 engine with Weber 40's fitted. This is my first experience with a carbed engine. It came to me with the fuel block/pressure regulator pictured below. It was marketed or made by PMO. It has a broken fuel barb and I need to repair or replace it.
My question: Is this a good system? It is "1 in/4 out", 2 out to carbs, 1 out to gauge, 1 out to tank. The return to the tank regulates the pressure with a hose clamp that restricts the outflow to the tank. Should I fix or replace this or is there a better system. Haven't checked to see what pump I have yet. It has been moved up front. Haven't talked to PMO yet either. Thanks for any advice. Expect more questions in the next week or two as the install proceeds (wiring? breather hoses?). Stay tuned. Attached image(s) |
Aaron Cox |
Apr 25 2003, 01:50 PM
QUOTE(seanery @ Apr 24 2003, 03:28 PM) Call me a nervous nelly but I agree with Rhody's post earlier. I don't think I could trust that setup. I'd go out and spend $45 and get a facet, mount it like the 75 cars did up front and be happy and safe with a new low pressure pump. (This is how I did my -6 conversion by the way). I did this on my 2.0 /4. 45 for a facet? i payed $23 New in box. there is a veedub resto/custom place that sells everything for cheap. i mounted my pump under the gas tank, in that little acces hole- drilled through passenger footrest and bolted it in.....does everynody's car have a big contoured styrofoam block under passenger footwell/ firewall? |
Lo-Fi Version | Time is now: 8th May 2024 - 11:28 AM |
