Question about plumbing Webers |
balthazar |
Apr 25 2003, 06:59 PM
P-car junkie Group: Members Posts: 161 Joined: 23-March 03 From: Arvada, Colorado Member No.: 464 |
VW-058046300- is the part number off a pump I pulled from a 74' 1.8 rust- bucket. This is very similar to your number. Prolly stock or OE replacement...IMHO
Porsche Rescue |
Apr 25 2003, 07:22 PM
Thanks Balthazar, sounds like I have a stock FI pump.
I am waiting for call from PMO. Faxed them today. Kevin, what is pr? |
rhodyguy |
Apr 26 2003, 07:09 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,060 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
pressure regulator. perhaps i should'nt be so lazy and stop throwing abreviations in. sorry. i've got a couple of facets lying around jim. do you want to try one out? mail to your place would be around 4 bucks. their just in the way in a drawer. i know for a fact that the one off the white wreck (moby dick, can't seem to get it out of the driveway, my nemisis) is functional.
kevin |
Porsche Rescue |
Apr 26 2003, 09:50 AM
Thanks Kevin. I have a facet on the shelf too. I am going to wait for a response from PMO, then probably hook up the existing system and check the pressure as Brad suggested. If it seems risky, I will go with the rotary like yours. For only $42 might as well have quiet. Is there a regulator shown in the picture of your pump? I see only the pump and 2 filters.
rhodyguy |
Apr 26 2003, 10:37 AM
jim, the small canister with the arrow is the regulator assem that comes WITH the pump. pre assembled and ready to go. if you have to buy an adjustable regulator it would drive the cost of a new facet to about the same price, and imho you still need a fp gauge. go to the cb performance site. i still intend to install a fuel pressure gauge when i complete my swap.
kevin Attached image(s) |
Brad Roberts |
Apr 26 2003, 10:49 AM
Those regulators are junk. (sorry.. I stopped running them in 1990 when I was 20 years old) again.. the typical carb pumps put out what you need without a regulator.
If your doing the car correctly (and want a regulator) pop for the real thing and buy a Mallory from Summit racing. The gauge is a good idea if you fiddle with tuning and setting the floats. Most people dont. B |
Porsche Rescue |
Apr 28 2003, 10:38 AM
Sean, your faith in Richard at PMO is well placed.
I faxed him about noon Friday and he called at 9:30 this morning. Pretty good service considering I was not a customer and only "inherited" a PMO part. He said they still produce the device and sell it with their carb conversion kits for CIS 911 pumps which are 90 lb. pumps. The high pressure is only created by the restriction created by the FI pressure regulator. He said as long as my return line to the tank has no restrictions (kink/pinch, etc) I can use the clamp to create the restriction in the return line to dial in the correct pressure. The only way the pump would generate 30 lbs. is if some other restriction would plug things up. Think I'll use the system. |
Brad Roberts |
Apr 28 2003, 10:42 AM
I couldnt imagine PMO selling anything that didnt work.
Cool. Get the car running. Oh.. Kevin.. juts for fun.. The regulator in your pic above is set to wide open on number 6. Throw it away.. its not doing anything. That is the regualtor that builds pressure in the line instead of bleading it off thru a return line like the PMO and factory setup. B |
rhodyguy |
Apr 29 2003, 07:35 AM
brad, i don't use that fpr any more. i use the cb unit in the 72 that will be transplanted into the 73.
kevin |
Lo-Fi Version | Time is now: 26th April 2024 - 01:35 AM |
