Check your CV bolts, Mine came off a few minutes ago |
ChrisReale |
Jul 12 2004, 10:41 PM
Luckily I was one block from my apartment, but it still sucked having to hold the flashlight with my knees while I put the drive shaft back on. Check your torque to make sure it is correct. I have been meaning to do this for a few days, and it bit me in the ass. Dont let it happen to you (IMG:style_emoticons/default/slap.gif)
Trekkor |
Jul 12 2004, 10:52 PM
What torque on those little bolts?
KT |
mightyohm |
Jul 12 2004, 11:57 PM
Jul 13 2004, 12:17 AM
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Britain Smith |
Jul 13 2004, 12:40 AM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
I actually picked up a 8mm Allen socket to allow me to properly torque my CV bolts. I recently put in a set of CV gaskets because for some reason the previous owner did not have any. I need to make my way up to HPH and get the proper wave washers before the autocross this weekend...
-Britain |
airsix |
Jul 13 2004, 12:42 AM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
QUOTE(SirAndy @ Jul 12 2004, 10:17 PM) Ayup. Me too. Hit me Thursday on the way home from work. Lucky me it was an outboard joint so it didn't flip the axle around like a gian fly-cutter. Double lucky me - I was only 50 yards from my driveway. Didn't even break a sweat pushing it home. No carnage. Just cleaned out the joint, got a gasket out of my stash and bolted it all back together Saturday. Gotta start checking them bolts more often. I thought twice per year was enough. Guess not. -Ben M. ps - This is my first breakdown with this car in the 5 years I've had it as a spring/summer/fall daily driver. Not bad. |
tdgray |
Jul 13 2004, 05:47 AM
Thank God Nemo is not here to see this Group: Members Posts: 9,705 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
Obviously there has been quite a bit of this lately (IMG:style_emoticons/default/ohmy.gif)
I guess I have a question then. Why can't you use lock-tite on these bolts? (IMG:style_emoticons/default/confused24.gif) Wouldn't that solve the problem? |
machina |
Jul 13 2004, 06:17 AM
anyone got a picture of the cv bolts safety wired?
what is the correct way to install them anyway? new bolts new gaskest? new boots? new lock tabs? sealant? we need to know dr |
ClayPerrine |
Jul 13 2004, 06:19 AM
Life's been good to me so far..... Group: Admin Posts: 15,443 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
QUOTE(tdgray @ Jul 13 2004, 03:47 AM) Why can't you use lock-tite on these bolts? (IMG:style_emoticons/default/confused24.gif) Wouldn't that solve the problem? BTDT... and it doesn't help. You can't get the bolts and holes clean enough to get the locktite to hold. Clay Perrine 74 914 1.8L (Betty's Daily Driver) 73 914 2.4L MFI Six (In process of reassembly) "It is better to wear out than to rust out." |
thomasotten |
Jul 13 2004, 06:48 AM
Senior Member Group: Members Posts: 1,544 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
It happened to me once and hit my transmission and cracked the shiftrod bushing guide right off. It can cause serious damage.
DNHunt |
Jul 13 2004, 07:36 AM
Between being so tight you can't break them loose, stripped heads or backing out on their own, they are a pain in the butt.
Dave |
davep |
Jul 13 2004, 09:59 AM
914 Historian Group: Benefactors Posts: 5,138 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
QUOTE(synthesisdv @ Jul 13 2004, 04:17 AM) what is the correct way to install them anyway? New bolts New washers New gaskets threads clean and dry use proper torque recheck a week later |
airsix |
Jul 13 2004, 11:06 AM
Can't really think of a good long-term solution. Like Clay said - you can't get the holes clean enough for locktite to hold. Safety-wireing would be a serious pain but might be worth it. Mike Mueller is a trained A&P mechanic - maybe he'll give us a tutorial on how to properly safety-wire a series of bolts.
-Ben M. |
Mueller |
Jul 13 2004, 11:14 AM
QUOTE What torque on those little bolts? 31 foot pounds according to the Haynes book Hey Ben, good idea, I still have to install my axles so this might be a good time to do this and document it unless someone else already has. QUOTE Mike Mueller is a trained A&P mechanic .....that only means I passed the test(s), not that I learned anything (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/smash.gif) |
Martin Baker |
Jul 13 2004, 11:17 AM
I just heard I sold my cars! Group: Members Posts: 1,140 Joined: 11-February 03 Member No.: 290 Region Association: Northern California |
I believe we should go with an "Emergency Action Time Compliance Technical Order" World Wide effective, grounding the entire 914 fleet until these matters have been corrected. Saftey first. I found mine loose one time, but it never seperated. I was Lucky. Have to run, three 747's calling my name today. I have all the info you would need to saftey bolts. I do it everyday. Almost, somedays these fine Boeing machines actually do not malfunction...lol
Porsche Rescue |
Jul 13 2004, 03:38 PM
Is everybody using the OE "schnorr" lock washers? I think they are critical to the assembly.
Zeke |
Jul 13 2004, 09:17 PM
Never left, but not right.... Group: Members Posts: 381 Joined: 26-January 03 From: Long Beach CA Member No.: 197 Region Association: None |
It's not easy to assemble the CV and not get grease on the bolts. Just before putting the CV on the flange, I clean out the threads with brake cleaner and a Q tip, plus a litte spiral brush used for cleaning spray guns. I check the CV for grease that will get into the bolt hole and clear that out.
After I get the CV up there, I Q tip it again to see how much grease oozed over into the bolt holes being careful not to shoot brake clean directly in the hole and filling up the joint. Then, with Locktite, I insert the bolts always using new serated washers cup facing away from the bolt head. 31 lbs. does the trick. Note: You have to have the flat steel piece that covers 2 holes. If I were to safety wire the bolts, I would wire those 2 together. |
RAR |
Jul 13 2004, 09:57 PM
Member Group: Members Posts: 189 Joined: 24-January 04 From: Washington state Member No.: 1,598 |
I couldn't get the bolts tight enough not to loosen, on my 911SC. Added serrated washers and that did the trick. The interesting thing is that they never loosened until I replaced an axle. They did not have washers as the car came from the factory, so I assume they were locktited. There is considerable discussion about this on the "large beaked bird", as well as photos (and heated discussion) of safety wiring.
Kerrys914 |
Jul 18 2004, 08:19 PM
WOW..what a nasty feeling when this happens.
My freak'n driver's side CV came off today (IMG:style_emoticons/default/sad.gif). Th dumb ass thing is I just got the CV tool in the mail and put off the task of tighting them up. The shaft fell onto the shift rod and made one hell of a racket and scared the hell out of me. I was going about 45 when it happened (IMG:style_emoticons/default/ohmy.gif) Called the wife and had her bring the new socket out to me, it was still in the PParts shipping box. Once she arrives and I look at the tool..........Son-of-a- BITCH...it's a 1/2" drive. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) So back in the car to get the 3/8 to 1/2 adapter from the house. Got the car home with only 3 bolts. One of the bolts sheared off (IMG:style_emoticons/default/sad.gif) Looks like I will need to buy a few now. Man I should have listened to you guys when I read this thread the first time (IMG:style_emoticons/default/beer.gif) Cheers Kerry "now in the fallen CV joint" club |
nine14cats |
Jul 18 2004, 08:31 PM
Bill Pickering -- 914-6 GT aka....Leeloo Group: Members Posts: 2,618 Joined: 10-February 03 From: Campbell, CA Member No.: 287 Region Association: None |
my cv's are safety wired. I realize my car is track only, but the safety wire is easy to snip during maintenance and adds a very measureable level of security. I'll shoot picks of my bolts with the holes in them....I've already taken them off with my engine drop in progress...
just my $0.02. Bill P. |
Lo-Fi Version | Time is now: 10th May 2024 - 03:43 PM |
