Bay Area: 1974 Porsche 914 2.0l (campbell) $7000 |
914World |
Sep 3 2011, 12:15 PM
Member #1 Group: Members Posts: 130,681 Joined: 23-December 02 From: World Wide Web Member No.: 1 Region Association: None |
Car has been set up as a street legal track and auto-x racer. The car was completely stripped to bare metal and repainted. Race 2.0L just installed, but final engine install has not been complete, so it is currently not running. Everything is included to finish the install, just not the time to complete it. The following is a list of items that have been done to the car.
Paint Strip exterior and interior to bare metal Acid etching primer all bare metal Base primer Two coats of silver paint exterior and interior Front Suspension New race bushing in lower control arm front and back Bilstein struts 22 mm torsion bars 22 mm sway bar New passenger side lower ball joint New wheel bearing Turbo tie rods bump steer kit Flex dam front air dam 15 by 7 steel rims Falken Azenis Sport 205 50 15 Rear Suspension New wheel bearings New race bushing in swing arm inside and out Bilstein shocks 16 mm rear sway bar 200lb. springs Adjustable spring purchases 15 by 7 steel rims Falken Azenis Sport 205 50 15 Race alignment and corner weighted Brakes 19mm master cylinder Replace Proportioning valve with T-fitting Stainless steel break lines Parking brake cables Remove dust shields Porterfield front brake pads Ferodo Rear brake pads Rebuilt front calipers Inspect and reinstalled all hard brake lines Engine Ceramic coated racing heaters Optical Pertronix points High pressure booster piston kit New dual oil sender unit Remote oil sender kit Remote oil cooler adapter plate Stainless steel oil lines AN fitting for remote oil cooler Front mounted oil cooler Custom fabricated oil line support Powder coated engine tin Solid motor mounts Solid transmission mounts New rear main seal Replace all fuel line on engine New injector seals New fuel filter New fuel lines at tank Replace tank sending unit Replace fuel pump New fuel pump mounts K&N air filter New battery tray Optima Batter Hard mount batter strap Reinforce clutch tube at fire wall and tunnel New clutch cable Heat shielding for cabling New shift rod bushing at firewall New Teflon shift rod bushing at transmission Race cam Stock fuel injection Stock pistons and cylinders Lighten flywheel Interior Bronze pedal bushings Replace brake light switch New tachometer Low oil warning light Removal of floor pan sound deeding material Removal of fire wall sound deeding material Welded in reinforcing plates for roll cage Roll cage Roll cage padding Carbon fiber dash skin Custom fiber dash with built in gages VDO oil pressure gauge VDO oil temp gauge Windshield to dash seal Replaced windshield Windshield seal Momo race seat Stock seat belts Replace head light switch Momo steering wheel Quick release steering wheel adapter Replace rear window New rear window seal Replace rear window to engine lid seal Gas shock rear trunk lid kit New rear trunk hinge mounts
Lo-Fi Version | Time is now: 29th April 2024 - 05:28 AM |
