Engine weights and sizes |
scotty b |
Sep 5 2011, 05:55 PM
I found this site while looking for some Am engine weights and thought it might be useful here for those doing swaps. I will say I don;t know how accurate the numbers are, but there seems to be quite a bit of research done.
http://www.35pickup.com/mulligan/weight.txt (IMG:style_emoticons/default/confused24.gif) |
BajaXJ92 |
Sep 5 2011, 07:19 PM
Extended Member Group: Members Posts: 2,146 Joined: 20-April 06 From: Prescott, AZ Member No.: 5,895 Region Association: MidAtlantic Region |
Glad I'm not the only one with this on my mind.
Cosworth V8 - 286lbs? (IMG:style_emoticons/default/piratenanner.gif) Sounds fun, if you can find one.... |
jimkelly |
Sep 5 2011, 07:28 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
scotty b |
Sep 5 2011, 07:33 PM
Glad I'm not the only one with this on my mind. Cosworth V8 - 286lbs? (IMG:style_emoticons/default/piratenanner.gif) Sounds fun, if you can find one.... I was actually looking at Am to Am swaps (IMG:style_emoticons/default/rolleyes.gif) The 401 I have for my Chevy truck is only 50 lbs heavier then the stright six that it came with (IMG:style_emoticons/default/biggrin.gif) from 105 h.p. 193 ft. lbs up to 325 h.p. 445 ft. lbs and only a 50 lb weight gain (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 16th May 2024 - 12:35 PM |
