Distributer Exploded, Have you seen this before? And do you have a spare? |
Millerwelds |
Sep 7 2011, 02:37 PM
Pleepleus Group: Members Posts: 715 Joined: 24-June 08 From: Grass Valley, CA Member No.: 9,206 Region Association: Northern California |
2.0 Djet. I changed out the plate due to a disconnected ground about a year ago and cleaned and lubed everything at that time. It has worked fine since then, til yesterday. Went to start the car and it did not sound right. Then no spark. Fiddled with a few things to make sure the wiring on the coil did not rattle loose etc, tried again and the distributer rotated 180 degrees and exposed this fancy new hole.
(IMG:style_emoticons/default/ar15.gif) Towed it home and dismantled the distributer this morning to find the following. It had been wearing away for a while based on the metal shavings. The shavings are not brass / bronze from the normal wear of the rotor /cap. Notice the wear on the FI trigger points plate too Part numbers for reference Here is a picture of the car for good measure. She looks real good (sitting in the garage!) (IMG:style_emoticons/default/headbang.gif) |
HAM Inc |
Sep 7 2011, 05:07 PM
Senior Member Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
Damn! Looks like it threw a rod!
Can't say I've ever seen that before. |
Cap'n Krusty |
Sep 7 2011, 05:34 PM
Damn! Looks like it threw a rod! Can't say I've ever seen that before. A weight came adrift. Either the spring was broken for a while, the pivot pin broke, or the hole in the weight wore through. The weight then jammed between moving parts and the housing. Bang. It's likely the problem was impending for some time. I've seen it before. The Cap'n |
Lo-Fi Version | Time is now: 3rd June 2024 - 08:39 AM |
