Distributer Exploded, Have you seen this before? And do you have a spare? |
Millerwelds |
Sep 7 2011, 02:37 PM
Pleepleus Group: Members Posts: 715 Joined: 24-June 08 From: Grass Valley, CA Member No.: 9,206 Region Association: Northern California |
2.0 Djet. I changed out the plate due to a disconnected ground about a year ago and cleaned and lubed everything at that time. It has worked fine since then, til yesterday. Went to start the car and it did not sound right. Then no spark. Fiddled with a few things to make sure the wiring on the coil did not rattle loose etc, tried again and the distributer rotated 180 degrees and exposed this fancy new hole.
(IMG:style_emoticons/default/ar15.gif) Towed it home and dismantled the distributer this morning to find the following. It had been wearing away for a while based on the metal shavings. The shavings are not brass / bronze from the normal wear of the rotor /cap. Notice the wear on the FI trigger points plate too Part numbers for reference Here is a picture of the car for good measure. She looks real good (sitting in the garage!) (IMG:style_emoticons/default/headbang.gif) |
Katmanken |
Sep 7 2011, 09:08 PM
You haven't seen me if anybody asks... Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
Jup,
Bosch distributors do that. Blew one in my 1973 Superbeetle. Spring went and the weight slung out through the side. Got a new one for $25 back then. |
Lo-Fi Version | Time is now: 20th May 2024 - 02:14 PM |
