Distributer Exploded, Have you seen this before? And do you have a spare? |
Millerwelds |
Sep 7 2011, 02:37 PM
Pleepleus Group: Members Posts: 715 Joined: 24-June 08 From: Grass Valley, CA Member No.: 9,206 Region Association: Northern California |
2.0 Djet. I changed out the plate due to a disconnected ground about a year ago and cleaned and lubed everything at that time. It has worked fine since then, til yesterday. Went to start the car and it did not sound right. Then no spark. Fiddled with a few things to make sure the wiring on the coil did not rattle loose etc, tried again and the distributer rotated 180 degrees and exposed this fancy new hole.
(IMG:style_emoticons/default/ar15.gif) Towed it home and dismantled the distributer this morning to find the following. It had been wearing away for a while based on the metal shavings. The shavings are not brass / bronze from the normal wear of the rotor /cap. Notice the wear on the FI trigger points plate too Part numbers for reference Here is a picture of the car for good measure. She looks real good (sitting in the garage!) (IMG:style_emoticons/default/headbang.gif) |
Thestigz06 |
Sep 13 2011, 01:04 AM
Aspiring Jarhead Group: Members Posts: 238 Joined: 22-February 11 From: Temecula, CA Member No.: 12,749 Region Association: Southern California |
2.0 Djet. I changed out the plate due to a disconnected ground about a year ago and cleaned and lubed everything at that time. It has worked fine since then, til yesterday. Went to start the car and it did not sound right. Then no spark. Fiddled with a few things to make sure the wiring on the coil did not rattle loose etc, tried again and the distributer rotated 180 degrees and exposed this fancy new hole. (IMG:style_emoticons/default/ar15.gif) Towed it home and dismantled the distributer this morning to find the following. It had been wearing away for a while based on the metal shavings. The shavings are not brass / bronze from the normal wear of the rotor /cap. Notice the wear on the FI trigger points plate too Part numbers for reference Here is a picture of the car for good measure. She looks real good (sitting in the garage!) (IMG:style_emoticons/default/headbang.gif) Totally random but could you tell me the tire size you're running? |
Millerwelds |
Sep 13 2011, 08:00 AM
[/quote] Totally random but could you tell me the tire size you're running? [/quote] 205-55-16 on Superlight 16x7 wheels. Very close to stock circumference so speedometer is still accurate. They fit the stock body but I rolled the lip on the rear fenders just to be safe. Car is lowered some as well. (IMG:style_emoticons/default/aktion035.gif) |
Thestigz06 |
Sep 13 2011, 01:55 PM
[quote name='Millerwelds' date='Sep 13 2011, 07:00 AM' post='1538538']
[/quote] Totally random but could you tell me the tire size you're running? [/quote] 205-55-16 on Superlight 16x7 wheels. Very close to stock circumference so speedometer is still accurate. They fit the stock body but I rolled the lip on the rear fenders just to be safe. Car is lowered some as well. (IMG:style_emoticons/default/aktion035.gif) [/quote] Well done! I haven't seen superlights on and non-flared car before....i think im in love!!! (IMG:style_emoticons/default/wub.gif) |
Lo-Fi Version | Time is now: 20th May 2024 - 01:18 PM |
