campbellcj |
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,635 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California ![]() ![]() |
L8Apex, I'm still "undecided" on how much I like these Kumho Ecsta V700's, but one positive factor is they are readily available and relatively cheap. About $110/ea new, full tread, I think. Mine have survived several hours of pretty aggressive track time so far, plus driving to-from events and the shop (I NEED a trailer), and are not gone yet.
Group: Posts: 0 Joined: -- Member No.: 0 ![]() |
yeah, I actually do have a set of V700's on some wheels that will only fit my CRX. I used them once at thunderhill and a few autox's. I'm thinking of getting them for the 914 also, or transfer them over for the track day. hehe. They are a bit on the heavy side though. I like them because they don't overheat in the summer unlike the Victoracers. sucks to have 1 flat hoosier (IMG:style_emoticons/default/blink.gif)
campbellcj |
What kind of pressures do the Ecsta V700's like in your experience? I typically ran the Victoracers and Hoosiers around 40psi hot, but I have heard all kinds of conflicting advice. Today the car felt very squirmy at about 29 cold/34-36 hot so I bumped them up about 4psi and it felt a lot better. Less squirm and sidewall deflection. But I didn't have the time, energy or knowledge to really optimize things.
at the track, I usually do about 32-35 cold, depending on the outcoming conditions. usually comes off at about ~40 ish hot, + or -. I think that was the most optimal my car felt. For AutoX, I just pump them up to about 35 no matter what. and take out a few if the car feels funny. But this is on my CRX, front drive, maybe a bit different, but I believe it would be a good starting point. I don't know a lot of people even running these tires at the track that much, so I don't get much feedback on them.
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
Well great.....we're all over the map on pressure for the V racers. Last time out (AX), I ran 26 & 28 cold (f-r) and they felt the bestest yet. (IMG:style_emoticons/default/blink.gif)
With the camber I was running, that may have been best. Dunno what it's gonna be like with 2.5 neg, tho....Prolly start out a bit higher? I may actually have to check temps........WAGs are more fun. |
JP, the victoracers are a different compound than the ECSTA V700's. I believe they are softer and heat up much quicker for autox use. i think people run about what you are running for pressures for those tires.
campbellcj |
I wasn't as anal about it as I maybe should've been, but I checked tire temps twice. The Ecstas were heating pretty evenly across the tread, which I guess means the camber is OK for them. (This is only with ~ -1.5). The temps were consistent front-to-back on each side of the car, with the "outside" (left, clockwise track) being hotter.
campbellcj |
By the way, what the he!! are you guys doing up so late/early, surfing this board at 3am (IMG:style_emoticons/default/blink.gif)
Jeroen |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe ![]() |
well... what the heck are you doing here at that ungodly time!
for me, it's 16.40 in the afternoon, so I'm just waisting work-hours (IMG:style_emoticons/default/biggrin.gif) cheers, Jeroen |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,018 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
Chris,
I just wanted to add my CONGRATS... on a successful outing. I really appreciate the pictures and write ups... helps motivate me to get back to my projects so that I can play too.... brant |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,206 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
L8, re "FWD push-mobile"--
Don't worry, you can still get a CRX to spin. Seen it quite a few times. In the "esses" at Sears Point, actually. The guy I was crewing for just didn't know how to take turn 9 (I think it was 9; 9 is the left-hander and 10 is the right-hander just before pit-in, right?) and looped it four out of ten laps his first time out there in that same spot. Yipe!! Didn't collect anyone, though--he was very careful about letting everyone else get through before he got to that part of the track. Happily, someone clued him in about how to take the turn before his second run group. Heh, I even got my CRX into a lovely four-wheel drift on the way to work this AM! (IMG:style_emoticons/default/biggrin.gif) --DD |
Dave, well, yeah, the car can be loose at times... hehe. About the spin at sears, you must be talking about Tyson? red ITA CRX with like 900lbs springs at the rear.
Ah, you know Tyson! (IMG:style_emoticons/default/biggrin.gif) Yup, that was his first-ever day at SP, and I was crewing for him.
--DD |
hehe,yeah, I know Tyson. I saw his car and was teasing him about it. "Vandals! Damn Vandals!" Then he saw me stuff the 914 into the tires at Laguna a few months later. I told him, "vandals! I just went to go take a dump, and when I come back, they steal my radio and beat up the car!"
(IMG:style_emoticons/default/ar15.gif) Blown out hoosiers. |
J P Stein |
I get home from wurk at midnight.
That's my story & I'm stickin' to it. |
Lo-Fi Version | Time is now: 21st July 2025 - 08:35 PM |
