Wevo'd and Evo'd, All done and looking good |
phillstek |
Sep 12 2011, 01:45 AM
Member Group: Members Posts: 350 Joined: 19-May 10 From: Byron Bay, Australia Member No.: 11,741 Region Association: None |
New Wevo'd 915 from the boys in Phoenix and Tangerine Racing Evo 6 exhaust system all bolted up.
Fired up the engine today after not being run for 12 years! Got oil pressure after a couple of cranks and then she sputtered into life. Webers were dismantled, cleaned and new gasket set fitted beforehand they still need tuning though. Couple of questions re: transmission. What is the recommended oil to use with the 915? Diff is a Wave Trac torque biasing unit. The clearance between the rear shift linkage rod and the headers appears to be very close. Although I haven't bolted it in yet, I fear the rod may contact the exhaust when attempting to shift. Anyone else running this set-up? Thanks again and all comments welcome. Phil Attached image(s) |
DEC |
Sep 12 2011, 02:10 AM
Senior Member Group: Members Posts: 630 Joined: 10-November 05 From: Rehburg Member No.: 5,104 Region Association: Germany |
Interesting header pipe guide/direction
What are the reasons for this? |
phillstek |
Sep 12 2011, 02:18 AM
Interesting header pipe guide/direction What are the reasons for this? I'm not really sure but I think this design gives a longer primary pipe by comparison to the type that go out to the side. Definitely improves the ground clearance and allows for easier removal of the driveshafts. It looks pretty cool too. Phil |
Bullethead |
Sep 12 2011, 04:18 AM
Oil Cooled heart Group: Members Posts: 897 Joined: 24-June 10 From: South Florida Member No.: 11,875 Region Association: South East States |
Nice. That's some header porn! Who makes that setup?
edwin |
Sep 12 2011, 06:09 AM
Member Group: Members Posts: 321 Joined: 20-May 09 From: Australia Member No.: 10,384 Region Association: Australia and New Zealand |
Looking real good there Phil.
Might have to drive mine to sydney for a ride in it. What size 6cyl did you go with? Cheers Edwin |
ChrisFoley |
Sep 12 2011, 06:44 AM
I am Tangerine Racing Group: Members Posts: 7,927 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Interesting header pipe guide/direction What are the reasons for this? I'm not really sure but I think this design gives a longer primary pipe by comparison to the type that go out to the side. Definitely improves the ground clearance and allows for easier removal of the driveshafts. It looks pretty cool too. Phil Both the primaries and secondaries have a tuned length, as opposed to most -6 headers which are designed for convenience and don't have optimized secondaries. |
Richard Casto |
Sep 12 2011, 09:00 AM
Blue Sky Motorsports, LLC Group: Members Posts: 1,465 Joined: 2-August 05 From: Durham, NC Member No.: 4,523 Region Association: South East States |
Couple of questions re: transmission. What is the recommended oil to use with the 915? Diff is a Wave Trac torque biasing unit. Phil, That all looks very nice! Regarding the transmission lubrication. Internally the 915 is not that different than a 901 (same type of synchros, etc.) It is the post 915 transmissions that have the Borg Warner style synchro that might need a different oil as is used in a 901/915. I would ask your transmission builder for their opinion and with respect to the TB Diff, I am assuming the manufacture would also provide lubrication recommendations. As this is a TB and not a clutch type, I am thinking that you should be able to use regular GL-5 WITHOUT needing something that has LSD specific friction modifiers. I have typed up this document awhile back and it might help... http://www.blueskymotorsports.com/index.ph...16&Itemid=6 Richard |
phillstek |
Sep 12 2011, 01:33 PM
Thanks for the comments.
Headers are Tangerine Racing Evo 6. I'm using their dual outlet muffler also. Edwin, engine is 2.4 E. I have 3.0 that's waiting to go in after a few tweeks. Chris, thanks for the clarification on pipe design. Thanks for the link, Richard. Phil |
Britain Smith |
Sep 12 2011, 02:19 PM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
As per Hayden at WEVO, you should be using Swepco.
-Britain |
phillstek |
Sep 12 2011, 06:02 PM
As per Hayden at WEVO, you should be using Swepco. -Britain I didn't think Swepco was readily available here. Most people were importing directly from the US themselves till very recently. After googling Swepco Australia, it turns out there is an importer here and their very first shipment arrives in about a week. I spoke to them just now and placed an order for the 201 product. Thanks for prompting that Britain. Here is a picture of the linkage clearance issue I refer to. Thoughts and comments welcome as usual Phil Attached image(s) |
ChrisFoley |
Sep 12 2011, 07:33 PM
I put the 4cyl car with a WEVO (that I mentioned in an email) up on the lift this afternoon.
As far as I can tell, at the tranny connection, the WEVO shift rod is a couple inches higher than the stock sideshift. It isn't any farther to the left though, so there really should be no interference when both ends are connected. |
phillstek |
Oct 31 2011, 04:12 PM
I put the 4cyl car with a WEVO (that I mentioned in an email) up on the lift this afternoon. As far as I can tell, at the tranny connection, the WEVO shift rod is a couple inches higher than the stock sideshift. It isn't any farther to the left though, so there really should be no interference when both ends are connected. The linkage ended fitting really nicely without any modification. No issues with fouling the exhaust and I can actually shift through a tight 'H' pattern now rather than the giant, vague 'O' pattern of the old 901. If anyone is requiring an exhaust system for their /6 they would be hard pressed to find anything that comes close to the TR Evo 6 in terms of value, quality, appearance and design. Thanks for all of your help Chris. Phil Attached thumbnail(s) |
SirAndy |
Oct 31 2011, 05:18 PM
Resident German Group: Admin Posts: 41,650 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
JmuRiz |
Oct 31 2011, 08:01 PM
914 Guru Group: Members Posts: 5,427 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Sweet setup, looks great!
PanelBilly |
Nov 1 2011, 09:46 AM
914 Guru Group: Members Posts: 5,807 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
That looks too good!
Lo-Fi Version | Time is now: 20th May 2024 - 01:00 PM |
