Can someone explain to me.., what it means to index torsion bars? |
mike_the_man |
Jul 16 2004, 09:03 AM
I like stuff! Group: Members Posts: 1,338 Joined: 11-June 03 From: Regina, Saskatchewan, Canada Member No.: 809 |
I've heard this mentioned when lowering the front end, but I'm not real sure what it means. Do the torsion bar adjusting end caps have to be in the same spot (same number of splines) on each torsion bar? If not, and you start cranking on the adjuster till the ride height is even, would one bar be more pretensioned than the other? Does any of this make sense???
What's happening is that I lowered the front of the car, not a whole lot, and added the bump steer kit, but when I go over a bump, the front end feels light. It feels like I'm still getting some bump steer, or something. I'm not quite sure how best to describe it. I haven't had it aligned yet, so that could be part of the problem, but I want to make sure I have everything else set up right first, then get it aligned. Sorry for the long post, and thanks, |
Mueller |
Jul 16 2004, 09:47 AM
rough description:
car up in air, looking at the drivers side from the front of the car, the a-arm should be pointing to the 4-5 o'clock position. Put the adjuster in the middle range... when you put the car back down on the ground, see if you like the ride hieght, if not, you can turn the bolt. If you run out of adjustment before obtaining the perfect ride height, you'll have to raise the car back up, pop off the adjusment cap and move it clockwise or counter-clockwise a few splines......it's a trail and error thing, unless there is documention that I do not know about (highly likely, LOL) |
Lo-Fi Version | Time is now: 19th May 2024 - 06:08 AM |
