Can someone explain to me.., what it means to index torsion bars? |
mike_the_man |
Jul 16 2004, 09:03 AM
I like stuff! Group: Members Posts: 1,338 Joined: 11-June 03 From: Regina, Saskatchewan, Canada Member No.: 809 |
I've heard this mentioned when lowering the front end, but I'm not real sure what it means. Do the torsion bar adjusting end caps have to be in the same spot (same number of splines) on each torsion bar? If not, and you start cranking on the adjuster till the ride height is even, would one bar be more pretensioned than the other? Does any of this make sense???
What's happening is that I lowered the front of the car, not a whole lot, and added the bump steer kit, but when I go over a bump, the front end feels light. It feels like I'm still getting some bump steer, or something. I'm not quite sure how best to describe it. I haven't had it aligned yet, so that could be part of the problem, but I want to make sure I have everything else set up right first, then get it aligned. Sorry for the long post, and thanks, |
mike_the_man |
Jul 16 2004, 10:03 AM
Bump steer is one thing that I more or less understand (probably about as well as I understand anything, anyway), but I installed spacers on the rack, and the steering rack arms are more or less parallel, so there shouldn't be much bump steer, correct? I'm thinking an alignment should clear up most of it.
Lo-Fi Version | Time is now: 19th May 2024 - 05:28 AM |
