Can someone explain to me.., what it means to index torsion bars? |
mike_the_man |
Jul 16 2004, 09:03 AM
I like stuff! Group: Members Posts: 1,338 Joined: 11-June 03 From: Regina, Saskatchewan, Canada Member No.: 809 |
I've heard this mentioned when lowering the front end, but I'm not real sure what it means. Do the torsion bar adjusting end caps have to be in the same spot (same number of splines) on each torsion bar? If not, and you start cranking on the adjuster till the ride height is even, would one bar be more pretensioned than the other? Does any of this make sense???
What's happening is that I lowered the front of the car, not a whole lot, and added the bump steer kit, but when I go over a bump, the front end feels light. It feels like I'm still getting some bump steer, or something. I'm not quite sure how best to describe it. I haven't had it aligned yet, so that could be part of the problem, but I want to make sure I have everything else set up right first, then get it aligned. Sorry for the long post, and thanks, |
mike_the_man |
Jul 19 2004, 01:51 PM
Hmmm, a loose U joint. You may be on to something there. With the front of the car up in the air, when I crank the steering wheel from lock to lock I hear a clunking sound, regularly, maybe every half turn or so. A loose U joint could be the cause. I'll investigate tonight.
Lo-Fi Version | Time is now: 27th May 2024 - 07:25 PM |
