| jim_hoyland |
Sep 23 2011, 06:31 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,157 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
(IMG:style_emoticons/default/birthday3.gif)
In addition to a boot (bellows) being a good idea, while I was helping Kapt Kaos inspect and reinstall a clutch cable last Tuesday evening, I noticed that he had a retaining ring that secures the cable sheath to the pulley housing (a washer with a tab sticking out on one side that bends into the hole on the side of the housing). I had never seen one of those before. They go on the inside and act as a keeper so the clutch cable doesn't slide out. Still have my original one. Attached image(s)
| Dave_Darling |
Sep 23 2011, 06:44 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,367 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Euro, that is a stock part. Part number 914 423 283 00, "tab washer".
--DD |
| jcd914 |
Sep 23 2011, 07:02 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,098 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
I just replaced my clutch cable after seeing the frayed bits sticking out at the roller. When I took it off, it was actually WORSE at the end just inside the housing. The cable bits broke at the friction point where the housing ends in a metal circle and were lumped up inside the housing, out of sight completely. So, if you see any cable fray at all it is worth a closer look or quick replacement. I went with the Terry Cable version. (IMG:style_emoticons/default/beerchug.gif) Exactly same place where mine frayed and broke. Did you find foreign material in the wire too ? Seems like a boot could really protect this area----anyone seen one ? I referred to the boot/bellows since it would keep dirt and grit out of the end of the cable housing where you seem to indicate the cable failed. This is where I see them tend to fail. There was never a boot that covered the roller and maybe if there was only dry lube (like used on high end bicycle chains) on the exposed cable and roller there would not be a bunch of grit stuck to your cable and roller. Me, I make sure the cable is lubed and the bellows in place and then wipe the exposed cable and the roller clean. The failure rate of cables never seemed excessive to me and they are not too tough or expensive to replace so doing anymore did not seem necessary. Jim |
| jim_hoyland |
Sep 24 2011, 09:23 AM
Euro, that is a stock part. Part number 914 423 283 00, "tab washer". --DD Also called a Cable Stop Plate as shown in the PP catalog. Still available Attached image(s)
| Drums66 |
Sep 24 2011, 11:36 AM
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
Euro, that is a stock part. Part number 914 423 283 00, "tab washer". --DD Also called a Cable Stop Plate as shown in the PP catalog. Still available I've encountered(bought) so many 914's that are missing this part?(it helps) (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/flag.gif) |
| euro911 |
Sep 25 2011, 11:28 AM
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,951 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California
Euro, that is a stock part. Part number 914 423 283 00, "tab washer". Also called a Cable Stop Plate as shown in the PP catalog. Still available--DD |
| euro911 |
Dec 16 2011, 02:14 PM
Euro, that is a stock part. Part number 914 423 283 00, "tab washer". Also called a Cable Stop Plate as shown in the PP catalog. Still available--DD Does anyone out here have a (cheap) used one laying around that they could pop into an envelope? (IMG:style_emoticons/default/popcorn[1].gif) |
| jim_hoyland |
Dec 16 2011, 04:31 PM
Euro, that is a stock part. Part number 914 423 283 00, "tab washer". Also called a Cable Stop Plate as shown in the PP catalog. Still available--DD Does anyone out here have a (cheap) used one laying around that they could pop into an envelope? (IMG:style_emoticons/default/popcorn[1].gif) That helps explain why so few 914's still have it.... (IMG:style_emoticons/default/biggrin.gif) |
| 914Mike |
Dec 17 2011, 03:08 AM
Member ![]() ![]() Group: Members Posts: 330 Joined: 27-January 03 From: San Jose, CA Member No.: 198 |
In addition to a boot (bellows) being a good idea, while I was helping Kapt Kaos inspect and reinstall a clutch cable last Tuesday evening, I noticed that he had a retaining ring that secures the cable sheath to the pulley housing (a washer with a tab sticking out on one side that bends into the hole on the side of the housing). I had never seen one of those before. Cable stop plate 914-423-283-00 $9.00 from Pelican (the first place I looked.) |
| rgalla9146 |
Dec 17 2011, 06:59 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,024 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
In addition to a boot (bellows) being a good idea, while I was helping Kapt Kaos inspect and reinstall a clutch cable last Tuesday evening, I noticed that he had a retaining ring that secures the cable sheath to the pulley housing (a washer with a tab sticking out on one side that bends into the hole on the side of the housing). I had never seen one of those before. Part # 914 423 283 00 supposed to be replaced with new cable but most often reused with no down side. |
Lo-Fi Version | Time is now: 17th November 2026 - 08:44 AM |
