Wiper Interval Relay, need part number ... |
SirAndy |
Apr 24 2003, 11:05 PM
Resident German Group: Admin Posts: 41,614 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
guys,
my new wire-harness (73) came with the optional Windshield Wiper Interval Relay addition, but unfortunately WITHOUT the actual relay itself. I used the Haynes Manual to hook up the wires correctly, which wasn't too bad, but the manual does not list the actual type of relay needed. it must be similar to the square blinker relay, except that it should have 5 prongs instead of just 4 (one additional in the center). also note that the prongs are NOT the round ones used on most of the other relays, but rather the flat type. anyone here who has the interval option installed or happens to know the relay part number? thank you very much (IMG:style_emoticons/default/pray.gif) Andy |
MarkV |
Apr 24 2003, 11:22 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
Cant find a different # for int. wipers (IMG:style_emoticons/default/confused24.gif)
70-72 / 914 616 410 00 73-76 / 477 955 531a This might not help: tech article |
SirAndy |
Apr 24 2003, 11:49 PM
thanks for the info.
"The original five pin relay was no longer available." outsch! is that the end of it? (IMG:style_emoticons/default/sad.gif) |
eitnurg |
Apr 25 2003, 10:13 AM
Country Member Group: Members Posts: 150 Joined: 31-December 02 From: Nairobi Member No.: 62 Region Association: None |
Get one of these. Bosch p/n 0 986 335 058-001, 'Easytronic' variable interval relay. The terminals should be compatible, & they really are the mutt's nuts.
Attached image(s) |
Bleyseng |
Apr 25 2003, 10:16 AM
Aircooled Baby! Group: Members Posts: 13,034 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
I have one in my parts bin at home. Buddy you should have posted this yesterday as I am in San Fran now being the tourist with Monique.
Off to Chinatown! If you can wait I can ship it to you, later. Geoff |
SirAndy |
Apr 25 2003, 11:57 AM
QUOTE(Bleyseng @ Apr 25 2003, 09:16 AM) If you can wait I can ship it to you, later. thanks! i can wait (IMG:style_emoticons/default/rolleyes.gif) Andy |
SirAndy |
May 1 2003, 10:26 PM
hey Geoff,
let me know where to send to $$$ (IMG:style_emoticons/default/wink.gif) oh, and have you made up your mind on the price now that you know what a NEW one costs (IMG:style_emoticons/default/rolleyes.gif) thanks again, hope to see you again soon, Andy |
ThinAir |
May 3 2003, 10:10 AM
Best friends Group: Members Posts: 2,539 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
Does anyone have a picture of one of these installed in its proper place? Years ago I bought a relay, then found out there was nowhere in my 72 to put it. Now that I've got a 73 I think I'm supposed to have a spot, but I don't know where to look.
Bleyseng |
May 3 2003, 02:25 PM
They plug in to a loose 5 pin connector that hooks to the drivers Cowl support.
Geoff |
markb |
May 3 2003, 06:30 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
Hmmm, I've got a 72 with 73 stuff (seat belt light, etc) I've wanted to do this to. It's got some empty relay connecters. Can somebody post pics?
SirAndy |
May 3 2003, 06:31 PM
QUOTE(ErnieDV @ May 3 2003, 09:10 AM) Does anyone have a picture of one of these installed in its proper place? Years ago I bought a relay, then found out there was nowhere in my 72 to put it. Now that I've got a 73 I think I'm supposed to have a spot, but I don't know where to look. it's actually mounted to one of the support brackets (drivers side) in the front trunk, right behind the gas-tank, next to the fresh-air box. you need the (optional) harness that goes to the wiper-motor, if you don't have that already. i got mine with the new '73 wire harness ... Andy |
SirAndy |
May 3 2003, 06:32 PM
QUOTE(markb @ May 3 2003, 05:30 PM) Can somebody post pics? i can post pics on monday ... |
markb |
May 3 2003, 06:36 PM
Thanks, Andy. I've got a couple late parts cars at the yard, and a whole harness at the shop. Maybe I can find something if I know what to look for. It'd be cool on the 70 too (work it into the stock twist type switch). Geez, that's all I needed, more things to screw around with.... (IMG:style_emoticons/default/sad.gif)
Jeff Krieger |
May 3 2003, 06:45 PM
Unregistered |
I guess the intermittent wiper was an option even on a '73 2.0? I have a '73 2.0 and I don't have intermittent wipers or a rear defrost.
SirAndy |
May 3 2003, 06:49 PM
QUOTE(Jeff Krieger @ May 3 2003, 05:45 PM) I guess the intermittent wiper was an option even on a '73 2.0? I have a '73 2.0 and I don't have intermittent wipers or a rear defrost. yes, option from '73 onwards. didn't see it as a option for '70-'72. have to look at my little book again ... the '73 and later have the mounting hole for the relay already drilled in the support bracket, early cars don't have the hole ... |
Jeff Krieger |
May 3 2003, 06:54 PM
Unregistered |
QUOTE(SirAndy @ May 3 2003, 05:49 PM) QUOTE(Jeff Krieger @ May 3 2003, 05:45 PM) I guess the intermittent wiper was an option even on a '73 2.0? I have a '73 2.0 and I don't have intermittent wipers or a rear defrost. yes, option from '73 onwards. didn't see it as a option for '70-'72. have to look at my little book again ... the '73 and later have the mounting hole for the relay already drilled in the support bracket, early cars don't have the hole ... Thanks. Intermittent wipers are a must have for where I live so that's one upgrade I will be doing when I buy replacement harnesses. |
anthony |
May 3 2003, 09:03 PM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
So what's the deal on this relay? Is it NLA? I've got two that don't work. Is that generic Bosch relay a drop-in replacement or do you have to rewire?
SirAndy |
May 3 2003, 09:34 PM
QUOTE(anthony @ May 3 2003, 08:03 PM) So what's the deal on this relay? Is it NLA? I've got two that don't work. Is that generic Bosch relay a drop-in replacement or do you have to rewire? supposedly NLA. i contacted AA and they said they have them in stock. a OEM replacement would be cool! Andy |
anthony |
May 3 2003, 09:43 PM
How much at AA?
SirAndy |
May 3 2003, 09:52 PM
QUOTE(anthony @ May 3 2003, 08:43 PM) How much at AA? i hope this link makes it, damm long url ... Relays at AA ... R477 955 531 a, relay for wiper control 1973-76, New $47.25 U477 955 531 a, relay for wiper control 1973-76, Used $35.00 G477 955 531 a, relay for wiper control 1973-76, Genuine $61.60 Andy |
Lo-Fi Version | Time is now: 3rd May 2024 - 11:09 PM |
