> Fuel Pump, Does Napa have one
Ian Stott
post Sep 25 2011, 12:20 PM
Did someone post Napa had a Bosch Fuel pump same part number as the one for our cars??
Ian Stott
Moncton
Canada
Ian Stott   Fuel Pump   Sep 25 2011, 12:20 PM
Joe Owensby   I am not sure about NAPA, but Advance auto has a ...   Sep 25 2011, 07:49 PM
Joe Owensby   NAPA also has a Bosch pump for a newer model year ...   Sep 25 2011, 07:51 PM
skaufmann   Yes the Napa pump is N69133. This pump is used in ...   Sep 25 2011, 08:37 PM
Prospectfarms   Its been a good pump. If you are replacing a three...   Sep 26 2011, 08:45 PM
Ian Stott   Napa in Canada doesn't have it, however if we ...   Sep 28 2011, 03:19 AM
r_towle   Napa in Canada doesn't have it, however if we...   Sep 28 2011, 03:53 PM
Prospectfarms   I've no idea what application, but follow this...   Sep 28 2011, 05:54 AM
budk   I'm a little confused... will this pump work w...   Sep 28 2011, 07:31 AM
scott_in_nh   I'm a little confused... will this pump work ...   Mar 8 2018, 08:48 AM
effutuo101   I got one at NAPA with next day delivery for about...   Sep 28 2011, 07:33 AM
Ian Stott   Ordered a new pump this afternoon, they are locate...   Sep 28 2011, 04:45 PM
Prospectfarms   Ian, Sorry for the rude question, but I have to as...   Sep 28 2011, 10:42 PM
ammason   I don't know if you're still looking for a...   Oct 24 2011, 11:54 PM
skaufmann   I don't know if you're still looking for ...   Oct 25 2011, 11:07 PM
doug_b_928   The N69133 is no longer on the NAPA website. Does...   Mar 8 2018, 08:43 AM
cwpeden   I just installed this on a friends 73 2.0L https:...   Mar 8 2018, 08:49 AM
doug_b_928   I just installed this on a friends 73 2.0L https...   Mar 8 2018, 09:04 AM
dr914@autoatlanta.com   The key is having the correct fuel filter and ho...   Mar 8 2018, 09:51 AM
dr914@autoatlanta.com   As a cheap alternative to the no longer available ...   Mar 8 2018, 08:55 AM
ClayPerrine   You can also use an Airtex E8445 pump or equivalen...   Mar 8 2018, 01:14 PM
- Lo-Fi Version Time is now: 1st July 2025 - 10:46 PM
