| Ian Stott |
Sep 25 2011, 12:20 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
Did someone post Napa had a Bosch Fuel pump same part number as the one for our cars??
Ian Stott Moncton Canada |
Ian Stott Fuel Pump Sep 25 2011, 12:20 PM
Joe Owensby I am not sure about NAPA, but Advance auto has a ... Sep 25 2011, 07:49 PM
Joe Owensby NAPA also has a Bosch pump for a newer model year ... Sep 25 2011, 07:51 PM
skaufmann Yes the Napa pump is N69133. This pump is used in ... Sep 25 2011, 08:37 PM
Prospectfarms Its been a good pump. If you are replacing a three... Sep 26 2011, 08:45 PM
Ian Stott Napa in Canada doesn't have it, however if we ... Sep 28 2011, 03:19 AM
r_towle
Napa in Canada doesn't have it, however if we... Sep 28 2011, 03:53 PM
Prospectfarms I've no idea what application, but follow this... Sep 28 2011, 05:54 AM
budk I'm a little confused... will this pump work w... Sep 28 2011, 07:31 AM
scott_in_nh
I'm a little confused... will this pump work ... Mar 8 2018, 08:48 AM
effutuo101 I got one at NAPA with next day delivery for about... Sep 28 2011, 07:33 AM
Ian Stott Ordered a new pump this afternoon, they are locate... Sep 28 2011, 04:45 PM
Prospectfarms Ian, Sorry for the rude question, but I have to as... Sep 28 2011, 10:42 PM
ammason I don't know if you're still looking for a... Oct 24 2011, 11:54 PM
skaufmann
I don't know if you're still looking for ... Oct 25 2011, 11:07 PM
doug_b_928 The N69133 is no longer on the NAPA website. Does... Mar 8 2018, 08:43 AM
cwpeden I just installed this on a friends 73 2.0L
https:... Mar 8 2018, 08:49 AM
doug_b_928
https... Mar 8 2018, 09:04 AM
dr914@autoatlanta.com The key is having the correct fuel filter and ho... Mar 8 2018, 09:51 AM
dr914@autoatlanta.com As a cheap alternative to the no longer available ... Mar 8 2018, 08:55 AM
ClayPerrine You can also use an Airtex E8445 pump or equivalen... Mar 8 2018, 01:14 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd March 2026 - 04:48 PM |
