Apollo Racer Build Thread, EZ36 Build-Up with ITB's! |
rnellums |
Sep 28 2011, 07:01 PM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
I am starting this thread to document the build of my recent acquisition of a car I am going to name Apollo. It was previously owned by a fellow out in Illinois and was sold to me via 914 LTD. From what I know It was a purpose built Auto X car, but only has about two hours of run time on the engine.
Here are the specs as I received it: Exterior Mods:
76-914 |
Mar 6 2014, 10:29 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,502 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Yup, looks like your right and I may have over thought this entire thing. Because after looking at both I see no difference, essentially. After all, I have cut most of the wires out of R-122 and the only ones necessary are those to the pump and pump relay. The relay needs to be on a switched and fused circuit and as I see it the rest will follow. (IMG:style_emoticons/default/beerchug.gif) Which brings me to: what the Hell does it do, exactly? If it controls anything it must be on/off. Because as I understand it the pressure is regulated at the rail, not at the pump. What say's the collective on this matter? Might have to take this one to a Suby board and get flamed. (IMG:style_emoticons/default/hissyfit.gif)
Chris H. |
Mar 6 2014, 05:35 PM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Yup, looks like your right and I may have over thought this entire thing. Because after looking at both I see no difference, essentially. After all, I have cut most of the wires out of R-122 and the only ones necessary are those to the pump and pump relay. The relay needs to be on a switched and fused circuit and as I see it the rest will follow. (IMG:style_emoticons/default/beerchug.gif) Which brings me to: what the Hell does it do, exactly? If it controls anything it must be on/off. Because as I understand it the pressure is regulated at the rail, not at the pump. What say's the collective on this matter? Might have to take this one to a Suby board and get flamed. (IMG:style_emoticons/default/hissyfit.gif) Yeah I'd be surprised if there is a separate "controller" for the fuel pump, what R122 might do is monitor the tank sensor, solenoids and stuff shown in the diagram which you won't use. Maybe the pump won't run if the tank pressure is too high which R122 is in charge of monitoring (IMG:style_emoticons/default/confused24.gif) ? Ya know, stuff like that.... On the SVX the power to the pump is controlled by the ECU. You run it through the relay then to the pump. Simple, just need "on" or "off" I think but you have a different car so I could be wrong. If you still want to ask about it 25RS is a much kinder place than NASIOC. They do swaps there too. |
Lo-Fi Version | Time is now: 17th May 2024 - 03:10 PM |
