Apollo Racer Build Thread, EZ36 Build-Up with ITB's! |
rnellums |
Sep 28 2011, 07:01 PM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
I am starting this thread to document the build of my recent acquisition of a car I am going to name Apollo. It was previously owned by a fellow out in Illinois and was sold to me via 914 LTD. From what I know It was a purpose built Auto X car, but only has about two hours of run time on the engine.
Here are the specs as I received it: Exterior Mods:
Chris H. |
Mar 7 2014, 10:07 AM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Great work man! I (IMG:style_emoticons/default/beerchug.gif)
Makes perfect sense once you figure it out doesn't it (IMG:style_emoticons/default/biggrin.gif) ? This wiring stuff will make you crazy... So R122 just cycles the pump to preserve it when not needed I guess. Kent you're not even using the original pump for that engine right (IMG:style_emoticons/default/confused24.gif) ? Sounds like you MIGHT be able to eliminate that "controller" but you'll want to be careful with the wiring if you take it out...that's a complicated setup and it goes into the ECU it looks like. I'd do some searches on the Subie sites before you decide. Also might want to start the car once before you do that... |
Lo-Fi Version | Time is now: 20th May 2024 - 11:24 PM |
