Apollo Racer Build Thread, EZ36 Build-Up with ITB's! |
rnellums |
Sep 28 2011, 07:01 PM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
I am starting this thread to document the build of my recent acquisition of a car I am going to name Apollo. It was previously owned by a fellow out in Illinois and was sold to me via 914 LTD. From what I know It was a purpose built Auto X car, but only has about two hours of run time on the engine.
Here are the specs as I received it: Exterior Mods:
ChrisFoley |
Sep 29 2011, 12:00 AM
I am Tangerine Racing Group: Members Posts: 7,920 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Nice buy, lots of potential there.
Do you know what camshaft was installed? RPM limit? A few things I see: Your header is way too small for a 2.4L. I guarantee it's holding the engine back - a lot. There's at least 10 more hp & 10 lb-ft torque available just by replacing the exhaust. You should have 4 EGTs to monitor the fuel mixture of each cylinder at WOT. Single O2 sensing doesn't have much value on a race car. I don't understand why the oil thermostat would be placed in the front trunk so close to the cooler. It should be closer to the engine to shorten the route when the oil is cold. Also, IMO hoses that long should be -12, not -10 (definitely not -8). No tuna can, or accusump? The engine won't last long once you start pushing it around at a competitive event. You should consider moving up to a dry sump oil system right away. 5 gal fuel cell isn't going to get you far. Fine for an AX toy but not big enough for even one on-track session. I'd lower the rear another half inch. Where's your adjustable brake bias control? Front anti-sway bar is too small. Stage 4 clutch is overkill. Your leg's gonna get a work out. |
Lo-Fi Version | Time is now: 3rd May 2024 - 03:18 AM |
