Apollo Racer Build Thread, EZ36 Build-Up with ITB's! |
rnellums |
Sep 28 2011, 07:01 PM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
I am starting this thread to document the build of my recent acquisition of a car I am going to name Apollo. It was previously owned by a fellow out in Illinois and was sold to me via 914 LTD. From what I know It was a purpose built Auto X car, but only has about two hours of run time on the engine.
Here are the specs as I received it: Exterior Mods:
ChrisFoley |
Sep 29 2011, 01:11 PM
I am Tangerine Racing Group: Members Posts: 7,920 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Kerry Hunter never made a 1 5/8" header. You should measure the dia of your primaries to be certain.
If I was selling a Tangerine Header for an engine such as yours I would recommend 1 3/4" primaries. You should be able to rev past 6500, and your HP peak may be above that anyway. Its hard to tell without more detailed cam info and empirical test data (dyno runs). I used to have a short stroke x 103mm engine (2.2L) with 48/38 valved heads and dual springs that revved to 7500 rpm and with a 1 3/4" Tangerine header it made 180 peak hp. The pressure plate is a direct bolt on and uses the same throwout bearing. |
Lo-Fi Version | Time is now: 3rd May 2024 - 05:26 AM |
