Apollo Racer Build Thread, EZ36 Build-Up with ITB's! |
rnellums |
Sep 28 2011, 07:01 PM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
I am starting this thread to document the build of my recent acquisition of a car I am going to name Apollo. It was previously owned by a fellow out in Illinois and was sold to me via 914 LTD. From what I know It was a purpose built Auto X car, but only has about two hours of run time on the engine.
Here are the specs as I received it: Exterior Mods:
Chris H. |
Mar 4 2014, 04:52 PM
Senior Member Group: Members Posts: 4,029 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
On the radiator setup, you might want to look at PJ Haun's website if you want to put it in the floor.
PJ Haun's Site Definitely want the fan to pull the air through the radiator, not push it as Stephen said. PJ has a fan under the rad and a lip to a create low pressure area. I was dead set on doing mine that way til I saw Mike (Ruby914)'s setup. He put the radiator a lot closer to the front of the car than most and then made that awesome carbon fiber ducting. Could be done in fiberglass too, which I might try. |
rnellums |
Mar 4 2014, 10:48 PM
On the radiator setup, you might want to look at PJ Haun's website if you want to put it in the floor. PJ Haun's Site Definitely want the fan to pull the air through the radiator, not push it as Stephen said. PJ has a fan under the rad and a lip to a create low pressure area. I was dead set on doing mine that way til I saw Mike (Ruby914)'s setup. He put the radiator a lot closer to the front of the car than most and then made that awesome carbon fiber ducting. Could be done in fiberglass too, which I might try. That definitely looks awesome. That's the route I think I'll take if the flat radiator doesn't cool enough. The floor has already been chopped out on mine by the PO, so it doesn't cost me anything to try it. If cooling is insufficient, then I'll switch to the fender well ducted setup. Thanks for the pointing link! |
Lo-Fi Version | Time is now: 3rd May 2024 - 03:54 AM |
