Apollo Racer Build Thread, EZ36 Build-Up with ITB's! |
rnellums |
Sep 28 2011, 07:01 PM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
I am starting this thread to document the build of my recent acquisition of a car I am going to name Apollo. It was previously owned by a fellow out in Illinois and was sold to me via 914 LTD. From what I know It was a purpose built Auto X car, but only has about two hours of run time on the engine.
Here are the specs as I received it: Exterior Mods:
76-914 |
Mar 6 2014, 09:11 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
In your factory manual; is there a page in the wiring sch's section that reads "Fuel System" or Fuel Pump" at the top of the page? Should be 2 of them. One for the 6 and one for the 4 cyl. Also, Look for two yellow wires. One with a blk stripe and one with a red stripe. Those are the + & - to the fuel pump. Maybe work backwards from there. Do you still have the car available to you? If so, can you shoot some pic's?
rnellums |
Mar 6 2014, 10:12 AM
In your factory manual; is there a page in the wiring sch's section that reads "Fuel System" or Fuel Pump" at the top of the page? Should be 2 of them. One for the 6 and one for the 4 cyl. Also, Look for two yellow wires. One with a blk stripe and one with a red stripe. Those are the + & - to the fuel pump. Maybe work backwards from there. Do you still have the car available to you? If so, can you shoot some pic's? No access to the car I am afraid. The closest thing to fuel system is "fuel gauge", but still no controller. In the 2001 engine wiring harness it shows more connections to the fuel pump, but they all go to the ECU or the fuel pump relay, which is controlled by the ECU as well. 2001 Schematic In the schematic I have for the 2003 model, it does indeed show a fuel pump control module. I'm thinking maybe I don't need it after all? 2003 Schematic |
Lo-Fi Version | Time is now: 2nd May 2024 - 10:50 PM |
