Apollo Racer Build Thread, EZ36 Build-Up with ITB's! |
rnellums |
Sep 28 2011, 07:01 PM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
I am starting this thread to document the build of my recent acquisition of a car I am going to name Apollo. It was previously owned by a fellow out in Illinois and was sold to me via 914 LTD. From what I know It was a purpose built Auto X car, but only has about two hours of run time on the engine.
Here are the specs as I received it: Exterior Mods:
Chris H. |
Mar 7 2014, 10:07 AM
Senior Member Group: Members Posts: 4,029 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Great work man! I (IMG:style_emoticons/default/beerchug.gif)
Makes perfect sense once you figure it out doesn't it (IMG:style_emoticons/default/biggrin.gif) ? This wiring stuff will make you crazy... So R122 just cycles the pump to preserve it when not needed I guess. Kent you're not even using the original pump for that engine right (IMG:style_emoticons/default/confused24.gif) ? Sounds like you MIGHT be able to eliminate that "controller" but you'll want to be careful with the wiring if you take it out...that's a complicated setup and it goes into the ECU it looks like. I'd do some searches on the Subie sites before you decide. Also might want to start the car once before you do that... |
AE354803 |
Mar 7 2014, 11:35 AM
Member Group: Members Posts: 232 Joined: 13-August 12 From: Southern California Member No.: 14,801 Region Association: Southern California |
Great work man! I (IMG:style_emoticons/default/beerchug.gif) Makes perfect sense once you figure it out doesn't it (IMG:style_emoticons/default/biggrin.gif) ? This wiring stuff will make you crazy... So R122 just cycles the pump to preserve it when not needed I guess. Kent you're not even using the original pump for that engine right (IMG:style_emoticons/default/confused24.gif) ? Sounds like you MIGHT be able to eliminate that "controller" but you'll want to be careful with the wiring if you take it out...that's a complicated setup and it goes into the ECU it looks like. I'd do some searches on the Subie sites before you decide. Also might want to start the car once before you do that... It doesn't cycle the pump operation, but it does cycle the pumps power supply. It's a Pulsed Width Modulator, it basically drops the voltage that is delivered to the pump by supplying different length bursts of voltage that average out to whatever lower voltage they are aiming for (12Volts pulsed to average out to 8 volts). My guess is they did it to extend the life of the pump/pump motor, maybe reduce evaporative emissions slightly? I didn't find out what happened if the R122 was removed, I'm guessing the computer may get upset, possibly go into limp mode assuming it has no or little fuel? It looked like they grabbed some STI R122's and plug and played them, allowed them to get higher output from their pumps. Their whole issue was that the voltage the pump was receiving was reduced by the R122 to only 12 volts (even at max demand) instead of battery voltage (13.5 ish) so the fuel pump was not delivering as much as it could and became a limiting factor for systems that were at the upper end of what the fuel pump could deliver (they were pushing injectors to 100% pulse). For whatever reason the STI R122's would give them a high maximum demand voltage than the Legacy GT R122's and that allowed them to deliver more fuel. |
Lo-Fi Version | Time is now: 3rd May 2024 - 12:49 AM |
