Problem with Clutch installation |
Bill Meyer |
Sep 30 2011, 11:03 AM
Newbie Group: Members Posts: 44 Joined: 11-October 07 From: Prairie Village, KS Member No.: 8,210 |
I posted a picture yesterday of my flywheel that had been machined (the bolts go beyond the face of the flywheel) and now I think that's going to be a problem. Upon installation as you can see the clutch arm doesn't have enough play to fully disengage the clutch, it hits the tranny housing. You can also see I had to fully thread the cable to get it even remotly tight, so I knew I had a problem here. Question is, what can I do? When I installed the pressure plate as I tightened the bolts the release fingers kept going in as the plate seated down, I'm guessing because the face the edge of the pressure plate mounts against has been turned down too much??? Bummed, now I got to pull it all out again, but do I need a new flywheel? Thanks for any suggestions! |
Lo-Fi Version | Time is now: 18th May 2024 - 02:23 PM |
