Old seatbelts giving you trouble?, How To: Update your seatbelts + a bonus |
thesey914 |
Jul 21 2004, 03:51 PM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
Would the original 914 belt have this pendulum design feature back in 1969 onwards?
I was thinking that if the reel mech works ( but not the pendulum )then it may be *as good* as the original belts. |
GaroldShaffer |
Jul 21 2004, 04:06 PM
You bought another 914? Group: Benefactors Posts: 7,620 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
QUOTE also worked so well for the passenger side, nobody has commented, meaning the belt works as it should. Worked well when Tony took me for a ride while in Austin Monday. QUOTE The inertial reel mechanism will work fine, but most seatbelts also have a pendulum lock-up mechanism that locks the belts when a certain amount of deceleration is sensed. The pendulum mechanism will not work properly unless the belts are mounted in the same orientation as the car they are designed for. I suspect the orientation is wrong for using the 944 belts in a 914. Just want you all to be safe! I was able to make the belt lock with a quick tug. Not a crash test, but it "seem" to work fine (IMG:style_emoticons/default/confused24.gif) -Garold |
lapuwali |
Jul 21 2004, 04:08 PM
The original 914s didn't have reel belts at all. They had fixed belts. I think the switchover was '72. Personally, I prefer fixed belts to inertia reel belts. Never any concern about the reel, and they can be cinched down to hold me in nearly as well as four-point belts, without quite as much hassle day to day as an actual harness.
Curvie Roadlover |
Jul 21 2004, 04:15 PM
Two trunks are better than one! Group: Members Posts: 2,025 Joined: 29-December 02 From: Southeast Michigan Member No.: 42 |
QUOTE(lapuwali @ Jul 21 2004, 05:08 PM) The original 914s didn't have reel belts at all. They had fixed belts. I think the switchover was '72. Personally, I prefer fixed belts to inertia reel belts. Never any concern about the reel, and they can be cinched down to hold me in nearly as well as four-point belts, without quite as much hassle day to day as an actual harness. Yeah, but they're a pain to re adjust when there are different drivers or passengers, not to mention when you want to roll the pass. window down or up and your belts are cinched. (IMG:style_emoticons/default/ohmy.gif) |
bondo |
Jul 21 2004, 04:17 PM
I did the same thing but with 924 belts. The 924 buckle is just like the 914 (on a sort of stiff cable) and mounts the same. I like the 924 buckle more because the release button is on the top (as mounted) not the side, and I find it easier to press. The 924 has the same pin issue, I just broke the pin off of mine as the mounting bolt holdes it securely enough, and the pull on it is always the same direction.
cha914 |
Jul 21 2004, 04:21 PM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 |
As Garold said above, the lock-up mechanism seems to work as well as it does in any car that I have driven in. I don't think the pendulum in these reels is a directional device.
When I was handling the reels unless I held it in the proper orientation (ie the belt being unreeled upwards) the belt would lock...so it would lock if you held the reel forward, or if you held it sideways. The same manufacture makes all the belts for all the porsches (REPA)...and from the several sets I have looked at they all seem to be very similar, so it would supprise me if they had direction specific mechanisms. But from a realworld standpoint, I have been able to lock the belt with a quick stop, so I imagine in an accident it would work as it should. Thanks for the concern, Tony |
cha914 |
Jul 21 2004, 04:25 PM
Mark D,
I didn't even check to see if the pin would unscrew...I have been doing so much grinding lately, it was the first thing I did when I saw it was a little longer than it needed to be... (IMG:style_emoticons/default/welder.gif) Yours, Tony |
McMark |
Jul 21 2004, 05:49 PM
If your backpad is still out you can unscrew the fat plastic cover (notice they're differnet thicknesses) and take a look at (picture) of the locking mechanism. I'll take a picture of a 914 one I have here.
McMark |
Jul 21 2004, 09:21 PM
Here's the stock pendulum trigger. You can see the top and the bottom of the pendulum, but the wire hanger is hidden by the wheel.
GaroldShaffer |
Jul 22 2004, 07:42 AM
So this woud work in a 70 -72 teener with the NON reel belts? As Curvie said, they are a pain to adjust.
tat2dphreak |
Jul 22 2004, 08:26 AM
wow, thanks for the info! (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/pray.gif)
great info!! itsa914: at least SOME of the 72s had these type belts... both of my '72s had them.. I think it was only 70-71 that didn't (IMG:style_emoticons/default/confused24.gif) |
GaroldShaffer |
Jul 22 2004, 08:30 AM
I knew 70 & 71 had them but wasn't sure about 72. (IMG:style_emoticons/default/confused24.gif)
Jul 22 2004, 02:58 PM
QUOTE(itsa914 @ Jul 22 2004, 05:42 AM) So this woud work in a 70 -72 teener with the NON reel belts? As Curvie said, they are a pain to adjust. In 72, they changed the firewall slightly to accomodate the inertia reel belt mechanism. Compare a 70 to a (late?) 72 some time. The backpad is also different. Some 72s had inertia-reel and some did not. I am not sure if it was early versus late in the year, or if the inertia reels were an option, or what. I think at least some of the 72s that had the adjustable belts also had the provision in the firewall to fit the inertia reel mechanism. --DD |
seanery |
Jul 22 2004, 03:15 PM
Does anyone know if you can get 924/944 belts new at a reasonable rate?
MarkV |
Jul 22 2004, 03:37 PM
I have a real clean set of used ones that I will sell for what I paid for them. $29.00
I bought a new set of 914 retractors a few years ago & they were getting lazy like the originals. The plan was to replace them w/ 944 units. I ended up cutting 24" of belt off the 914 units, they now work perfect. Was going to put the 944 units on Ebay. |
Qarl |
Jul 22 2004, 03:59 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
You're welcome! ha ha!
I did this mod years ago to my last 914. The inertia real worked great! Almost too great. Sometimes it was hard to change stations on the radio without the seatbelt grabbing. Good advice about the pin. I didn't realize that years ago either about the pin being removable. I don't think 944 seatbelts new are any cheaper. Check with the REPA company in the back of any PANO magazine. Later! (IMG:style_emoticons/default/cool_shades.gif) (IMG:style_emoticons/default/cool_shades.gif) (IMG:style_emoticons/default/cool_shades.gif) |
MarkV |
Jul 22 2004, 04:16 PM
brant |
Jul 22 2004, 04:18 PM
914 Wizard Group: Members Posts: 11,617 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
one question:
so is it the 944 fronts or 944 rears that should be sought out to use. brant |
Air_Cooled_Nut |
Jul 22 2004, 06:51 PM
914 Ronin - 914 owner who lost his 914club.com Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
The 944 seat belt and the 914 buckle look exactly like the ones in my '72 air-cooled VW and that's nice to know when looking for needed parts...
Nice write up! |
Joe Ricard |
Jul 22 2004, 07:28 PM
On my 74 I found some new belts in the rear seats of a late 80's Mercedes 300. Perfect fit straight bolt in also 10 bucks.
Right now my 70 has the 5 point cam lock and I am getting pretty tired of them. Plan to get racing soon so I will leave in and suck it up. I have the original non-retractable belts but the webbing is pretty bad so I will just suck it up some more. |
Lo-Fi Version | Time is now: 1st May 2024 - 07:08 PM |
