NEW PROBLEM, Tach & Gas gauge |
72914S |
Jul 21 2004, 08:14 PM
love this shot Group: Members Posts: 1,290 Joined: 10-July 03 From: Pensacola,Fl. Member No.: 900 Region Association: South East States |
What happened? now when I apply the brakes the tach quits and the gas gauge goes to empty. Not only then but when I put it in reverse same thing.And the alternator light is glowing dim (it goes bright when I hit the brakes).????? (IMG:style_emoticons/default/huh.gif)
ArtechnikA |
Jul 21 2004, 08:37 PM
fuse, i think. #9 comes to mind.
easy thing to check, anyway ... |
newdeal2 |
Jul 21 2004, 08:42 PM
Unregistered |
I had the same problem..change the fuse even if it looks good. Worked for me. |
72914S |
Jul 21 2004, 08:54 PM
Well it was the fuse. BUT it blew as soon as I hit the brake....must be a ground ? checked the one above the fuse panel (took it off cleaned and reattached and it still blows# 9) getting late,so tommrow I check the other two..battery ...transmisson. Are there anymore ??
East coaster |
Jul 21 2004, 08:58 PM
Senior Member Group: Members Posts: 1,675 Joined: 28-March 03 From: Brigantine, NJ Member No.: 487 Region Association: None |
I had this problem years ago and if I recall it was a bad ground. I just can't remember where it was bad ........sorry!
Lo-Fi Version | Time is now: 20th May 2024 - 09:31 PM |
