| Ian Stott |
Oct 6 2011, 05:09 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
As the title says (the idle is around 950/1000) but it doesn't drop down to that very fast, it is almost like driving a vehicle with a sticky throttle. I have just installed a new (rebuilt by Jeff Bowlsby) relay board and cleaned up my grounds and cleaned the engine compartment. Any ideas what is going on?
Ian Stott Moncton Canada |
| luskesq |
Oct 6 2011, 05:16 PM
Member ![]() ![]() Group: Members Posts: 276 Joined: 24-October 10 From: Fresno, CA Member No.: 12,303 Region Association: Central California |
Knowing what year, what engine and whether it is FI or carb'd would be helpful.
Keith |
| Ian Stott |
Oct 6 2011, 06:28 PM
Ooops, 73 2.0 all original D Jet.
| rnellums |
Oct 6 2011, 07:56 PM
Professional Enthusiast ![]() ![]() ![]() Group: Members Posts: 1,673 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
I had the same issue with mine when I rescued it from storage. 3-4 secnods after I let Off the throttle at 3k before it would drop. I replaced all the vacuum lines for starters, but the real issue was my AAR was stuck. I put PB in it and it don't seem the help much. I ended up pulling the top cap off and running a few hot/cold cycles wIth a blow torch and now all is well.
| Prospectfarms |
Oct 7 2011, 12:17 AM
Member ![]() ![]() Group: Members Posts: 495 Joined: 7-March 11 From: Louisville, KY Member No.: 12,801 Region Association: Upper MidWest |
As the title says (the idle is around 950/1000) but it doesn't drop down to that very fast, it is almost like driving a vehicle with a sticky throttle. I have just installed a new (rebuilt by Jeff Bowlsby) relay board and cleaned up my grounds and cleaned the engine compartment. Any ideas what is going on? Ian Stott Moncton Canada Could your throttle be sticking? Mine did, causing the idle to hang until I bumped the accelerator peddle. I cleaned it with carburetor cleaner. Its been said that a failing deceleration valve can produce a vacuum leak. You might check out Anders Since the TPS asserts a separate "idle circuit" when the throttle closes, I can't reason why the idle would ever "hang," unless the TPS is maladjusted or there is a physical problem with the throttle? That's a question not a statement of fact. |
| Dave_Darling |
Oct 7 2011, 12:27 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,338 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Some things that come to mind as possible causes:
Decel Valve sticking, hooked up wrong, or mis-adjusted. Vacuum leak. Advance in the distributor is sticking. Vacuum advance/retard hooked up incorrectly. --DD |
| r_towle |
Oct 7 2011, 08:12 AM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Some things that come to mind as possible causes: Advance in the distributor is sticking. --DD (IMG:style_emoticons/default/agree.gif) |
| BK911 |
Oct 7 2011, 09:13 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
I have this problem in a 356. If I keep the car in gear until the engine is at 1k rpms before I pop out of gear, perfect idle. If not, the idle slowly drops.
Do you guys think this indicates sticking advance plates or weak springs? Not to hijak, but if so, you may want to do this "test" to narrow down to weak dizzy springs or gummed up advance plates. |
| r_towle |
Oct 7 2011, 10:53 AM
The problem occurs when the old grease (40 year old grease at least) gets hot and becomes very sticky.
Its a 20 minute fix. Remove the advance plates, take out the little ball bearing and clean everything with your favorite cleaner. add new wheel bearing grease. Put it back in and set the dwell and timing. Not super hard to do...and it very cheap to do. I would not even waste the time testing...just do it if you have never done it...its part of the long term maintenance. If you really want to test it...try flicking the rotor back and forth to simulate advance, but do it while the distributor is really hot....right after a long drive on the highway.. It should SNAP back to no advance...if not, its dirty. Rich |
| Ian Stott |
Oct 10 2011, 11:31 AM
Well! Feeling pretty dumb on this one, new floor mats were creeping and putting pressure on the throttle, using my heel I pull the mat back and all is well. Just got back from Owl's Head in Maine, car ran great and what an absolutely fabulous place to visit, I give it an excellant rating and James Smith made sure we had some good roads to travel on! My buddy Steven got a trophy for his beautiful Ghia and we had really nice weather the whole time, super weekend.
| Chris Pincetich |
Oct 10 2011, 01:37 PM
B-) ![]() ![]() ![]() ![]() Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
OMG (IMG:style_emoticons/default/beerchug.gif)
Wasn't that the problem that cost Toyota millions $$$?? At least you didn't wildly accelerate and cause an accident. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 30th April 2026 - 10:19 PM |
