Unconventional DJet installation, Truly one-of-a-kind |
ChrisFoley |
Oct 6 2011, 08:47 PM
I am Tangerine Racing Group: Members Posts: 7,923 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
The engine is a 1911 I built to run D-Jet injection, originally intended for a customer's car, but he abandoned his project and left everything to me several years ago. I was running it with Dual Delortos with SSI HE's and a Tangerine IV muffler. It was my cold weather engine. The purpose of the current project was to develop an inexpensive FI setup which accomodates my horizontal cooling system. Stock type plenum systems won't fit over the flat fan. Systems which use ITBs generally aren't inexpensive, and are better suited to larger displacement, higher performance engines. Over the years I've collected a good selection of DJet hardware, both 1.7 and 2.0, so that seemed like the best place to start. So far I've only spent about $100, that's counting the small assortment of overstock materials and scraps already on hand at CFR. The only new purchases were the two silicone intake boots which connect the intake duct to the TBs. The injection system is all 914 DJet: Two 1.7L throttle bodies are mounted on separate tubular plenums, fabricated from the flange end of stock 1.7 intake runners and throttle body mounts from stock 1.7 plenums. The injectors are from a 2.0. The MPS is an AA special 2 liter unit, purchased in 1994 for my ITB race car. The ECU is a '73 2 liter unit. The air filter box is a modified 2 liter unit with a cold air intake inside the left rear fender well. The AAR is from a 1.7L. There is no decel valve or cold start valve. There's a balance tube between the two plenums - with take-offs for the MPS and the AAR. The TPS is on one of the TBs. The distributor vacuum advance and retard are connected to one of the TBs. I've already driven the car with K&N air filters mounted directly on the TBs. It runs great, but was rather loud right behind my head. Based on my A/F monitor, the mixture is almost perfect already. It idles smoothly at 850 rpm. The range of the idle mixture knob on the ECU allows me to set the idle too rich, too lean, or just right. We had to make special idle adjustment screws for the TBs to make the bypass hole smaller than normal, since each TB only feeds two cylinders. The relay board was moved up and back to accomodate the airbox. The airbox will be powdercoated now that the installation is finalized. I have a little more hose and wiring cleanup to do, but the wiring harness is totally stock, just routed a little differently across the engine. We did the install initially without surround tin, but the engine runs hotter than I like when it sits in traffic. Adding the tin is tomorrow's project. |
r_towle |
Oct 7 2011, 08:25 AM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I always thought twin turbos (small ones) would be easier to design while retaining the heat exchangers.
You now have a design for the FI that can leverage a twin turbo setup... If you do a deep search here Marty posted the original ad for the kit...and it had numbers on it of PSI and porjected HP. It was not a huge leap but I think it was near 150hp for a bolt on modification. Rich |
Lo-Fi Version | Time is now: 7th May 2024 - 11:21 PM |
