Zach's Carbs to Microsquirt conversion thread, 7/20/18 update |
VaccaRabite |
Oct 11 2011, 06:44 PM
En Garde! Group: Admin Posts: 13,407 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I am retrofitting this thread to be my full on conversion thread, documenting my change from dual 40 Webers to MSII fuel injection.
Here is what I have so far, and what I need: HAVE:
Built on 1.7 heads. Jake's 9530 cam (carb cam similar to Web 494) Mallory optical ignition ACCEL (UltraCoil) coil. SSI exchangers for exhaust. My goals for this project are to have near stock intake noise volume, better cold starting - especially in cooler weather, negate the bad effects or Ethanol on carbs, teach myself something about fuel injection. Since I already have a pretty good ignition system, I am not going to go after crank fired ignition at this time, but I am not ruling that out for the future. Before I begin the conversion, I am going to pull the engine and do a little refreshing and cleaning, including:
QUOTE I am getting ready to start my conversion form carbs to EFI. My goal is to use as much stock EQ as I can, but replace the sensors and such with modern, easy and cheaper to find stuff. Plus, since my car has a cam, the stock FI will not work. My engine has 1.7 4 bolt heads. 1) are the 1.7 and 1.8 intake runners the same? 2) Is the intake runner inside diameter smaller then the 2.0 intake runner ID? 3) is the throttle body for the 1.8 smaller then the throttle body for the 2.0? If the 1.8 TB is smaller then the 2.0, can the 2.0 TB be swapped in? Are 1.8 injectors high or low impedance? I am asking this as I will be able to get Joe's discarded 1.8 bits when he pulls his engine and starts going down the 2056 route. Zach |
FourBlades |
Oct 12 2011, 06:05 PM
From Wreck to Rockin Group: Members Posts: 2,052 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
I apologize if this is a hijack. I would like EFI for a lot of reasons as well but I
thought I would see in a quick and dirty way how much the carbs could be quieted down. The carb tops and plenum are just welded up exhaust pipe and 20 gauge sheet metal. I put eastwoodmat around the carb tops. The tubing, couplers, and cone filter are cheap FLAPS parts. I need to do some more tests but my initial results are 88 db with itgs at 900 rpm and 82 db at 760 rpm with my cheesy intake system. I was getting 104 db at 2600 rpm with itgs and never took a good reading with the new system at that rpm. I'll get on that. Now I can hear the exhaust a little but also a lot of general air cooled noise that is not intake related. This seems to help low end throttle response but obviously would be restrictive past a certain rpm. John |
Lo-Fi Version | Time is now: 29th March 2024 - 08:12 AM |
