Zach's Carbs to Microsquirt conversion thread, 7/20/18 update |
VaccaRabite |
Oct 11 2011, 06:44 PM
En Garde! Group: Admin Posts: 13,407 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I am retrofitting this thread to be my full on conversion thread, documenting my change from dual 40 Webers to MSII fuel injection.
Here is what I have so far, and what I need: HAVE:
Built on 1.7 heads. Jake's 9530 cam (carb cam similar to Web 494) Mallory optical ignition ACCEL (UltraCoil) coil. SSI exchangers for exhaust. My goals for this project are to have near stock intake noise volume, better cold starting - especially in cooler weather, negate the bad effects or Ethanol on carbs, teach myself something about fuel injection. Since I already have a pretty good ignition system, I am not going to go after crank fired ignition at this time, but I am not ruling that out for the future. Before I begin the conversion, I am going to pull the engine and do a little refreshing and cleaning, including:
QUOTE I am getting ready to start my conversion form carbs to EFI. My goal is to use as much stock EQ as I can, but replace the sensors and such with modern, easy and cheaper to find stuff. Plus, since my car has a cam, the stock FI will not work. My engine has 1.7 4 bolt heads. 1) are the 1.7 and 1.8 intake runners the same? 2) Is the intake runner inside diameter smaller then the 2.0 intake runner ID? 3) is the throttle body for the 1.8 smaller then the throttle body for the 2.0? If the 1.8 TB is smaller then the 2.0, can the 2.0 TB be swapped in? Are 1.8 injectors high or low impedance? I am asking this as I will be able to get Joe's discarded 1.8 bits when he pulls his engine and starts going down the 2056 route. Zach |
Brodie |
Nov 7 2011, 01:14 PM
Newbie Group: Members Posts: 39 Joined: 28-October 09 From: Kansas Member No.: 10,990 Region Association: None |
Zach, There are some calculations to determining throttle body size.
cfm = (Max RPM x Volumetric Efficiency x Cubic inches) / 3456 or max area of opening = (cfm x 2.4) / 300 feet per second Use 85% for an average guess on volumetric efficiency. If you have information on what the actual volumetric efficiency is use it, but I'm not sure how to get it. I would say that you need to calculate the area of the ID of all of the runners and make sure that they are at least as much as the throttle bottle. I would think that even a bit larger would be better. You want to flow as much air through the runners as the throttle body. Don't oversize the throttle body by too much because at fully throttle it's fine, but at idle you bump the throttle just a little bit and a large amount of air rushes in. I would think that would cause some grief. I haven't done this for myself yet because I have to get my car built from scratch, but when I do, these calculations will come in handy. (I think!) I don't know if this will help you any but through my research I found a few tidbits here and there, and wanted to pass them along. Good luck! |
Lo-Fi Version | Time is now: 28th March 2024 - 08:58 AM |
