Zach's Carbs to Microsquirt conversion thread, 7/20/18 update |
VaccaRabite |
Oct 11 2011, 06:44 PM
En Garde! Group: Admin Posts: 13,420 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I am retrofitting this thread to be my full on conversion thread, documenting my change from dual 40 Webers to MSII fuel injection.
Here is what I have so far, and what I need: HAVE:
Built on 1.7 heads. Jake's 9530 cam (carb cam similar to Web 494) Mallory optical ignition ACCEL (UltraCoil) coil. SSI exchangers for exhaust. My goals for this project are to have near stock intake noise volume, better cold starting - especially in cooler weather, negate the bad effects or Ethanol on carbs, teach myself something about fuel injection. Since I already have a pretty good ignition system, I am not going to go after crank fired ignition at this time, but I am not ruling that out for the future. Before I begin the conversion, I am going to pull the engine and do a little refreshing and cleaning, including:
QUOTE I am getting ready to start my conversion form carbs to EFI. My goal is to use as much stock EQ as I can, but replace the sensors and such with modern, easy and cheaper to find stuff. Plus, since my car has a cam, the stock FI will not work. My engine has 1.7 4 bolt heads. 1) are the 1.7 and 1.8 intake runners the same? 2) Is the intake runner inside diameter smaller then the 2.0 intake runner ID? 3) is the throttle body for the 1.8 smaller then the throttle body for the 2.0? If the 1.8 TB is smaller then the 2.0, can the 2.0 TB be swapped in? Are 1.8 injectors high or low impedance? I am asking this as I will be able to get Joe's discarded 1.8 bits when he pulls his engine and starts going down the 2056 route. Zach |
VaccaRabite |
Mar 7 2013, 08:48 PM
I got more stuff today!!!
Original Customs 100% eFI kit. Let McMark take the engineering out of your eFI project. (IMG:http://www.914world.com/bbs2/uploads_offsite/farm9.staticflickr.com-1435-1362710932.1.jpg) New fuel injectors? Coil on Plug? Hell yeah! (IMG:http://www.914world.com/bbs2/uploads_offsite/farm9.staticflickr.com-1435-1362710933.2.jpg) Prebuilt wire harness? Yup. (IMG:http://www.914world.com/bbs2/uploads_offsite/farm9.staticflickr.com-1435-1362710933.3.jpg) O2 sensor included? You better believe it. (IMG:http://www.914world.com/bbs2/uploads_offsite/farm9.staticflickr.com-1435-1362710933.4.jpg) Weathertight Microsquirt controller? Included. Can you say mounted in the engine compartment with no worries? Yes you can. (IMG:http://www.914world.com/bbs2/uploads_offsite/farm9.staticflickr.com-1435-1362710934.5.jpg) There are a couple things that I am missing yet, but I can start taking chuncks out of this job for real now. Zach |
Lo-Fi Version | Time is now: 19th April 2024 - 03:40 PM |
