bluhun |
Member ![]() ![]() Group: Members Posts: 91 Joined: 23-January 06 From: San Rafael, CA Member No.: 5,464 Region Association: Northern California ![]() |
(IMG:style_emoticons/default/headbang.gif) Does anyone know how to restore the reflective surface of the tail light housing after the coating has oxidized? Is there a way to remove the old chrome coating without destroying the plastic backing other than with elbow grease and fine steel wool, followed by a chrome or silver paint? Is there a solvent that will remove the old surface without destroying the plastic base?
jimkelly |
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region ![]() |
there is a recent thread where someone found some foil lined tape and applied it to his buckets - looked good - not sure how it will hold up to the heat of the bulbs though. jim
Bruce Hinds |
V-8 madness ![]() ![]() ![]() Group: Members Posts: 748 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest ![]() |
If all else fails, tin foil works great. Back in the day of 6 volt cars we'd put tin foil in to really brighten them up.
jimkelly |
dlee6204 |
Howdy ![]() ![]() ![]() ![]() Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 ![]() |
I've used the "chrome" paint in my light housings. I like it.
Post 89 in my progress thread... http://www.914world.com/bbs2/index.php?sho...95219&st=80 |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,757 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
(IMG:style_emoticons/default/agree.gif) I have one pristine bucket and one that was awful. I used the chrome paint on the crappy one. I was worried because the surface wasn't as reflective as the original chrome but when lit up at night there is absolutely no difference between the two. I took a pic but can't find it now. (IMG:style_emoticons/default/mad.gif)
Todd Enlund |
Resident Photoshop Guru ![]() ![]() ![]() ![]() Group: Members Posts: 3,251 Joined: 24-August 07 From: Laurelhurst (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest ![]() |
Oven cleaner may/should remove the old chrome. I have an idea on how to reapply the same factory type finish...
The original is vacuum plated with aluminum. To simulate this, I plan on spraying the housing with slow drying varnish, and applying powdered aluminum. When dry, I hope that it will buff into a nice shiny finish just like the original. |
campbellcj |
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,635 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California ![]() ![]() |
On a project years ago, I used the 'chrome paint' stuff from Eastwood made for this purpose, and the results were just fine.
Lo-Fi Version | Time is now: 30th July 2025 - 10:55 PM |
