"rebuilt" bus 2.0 engine, How do I tell what I have? |
bondo |
Jul 26 2004, 01:22 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
The 914 I recently bought came with a supposedly rebuilt bus 2.0. I decided to take it apart to see what I have. It is indeed a 2.0, it has a bore of 94 mm, and a stroke of around 71 mm. It still has very visible honing marks all the way around, and no noticable able ridge. But regarding it's history, I have some questions...
1. Do all VW cylinders have part numbers? I have taken off two cylinders so far and one has a part number (039 101 301C), one does not. 2. Is there an easy way to tell if someone just reamed off the ridge, honed it, and put in new rings to make it "rebuilt"? 3. How much smaller should the piston be than the cylinder? I've never rebuilt a VW engine, but I've never seen an engine where you can slide the piston back and forth (I can on this one) 4. All this stuff is going to be up for sale eventually... what is the best strategy for getting my money's worth while not screwing over any buyers? (part it out, sell it whole, sell it disassembled, etc..) |
SirAndy |
Jul 26 2004, 01:37 PM
Resident German Group: Admin Posts: 41,650 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
bondo |
Jul 26 2004, 02:14 PM
Dang, I was hoping I'd never incur the wrath of the no pics smileys.
Engine: Attached image(s) |
bondo |
camshaft (front half)
Attached image(s) |
bondo |
Jul 26 2004, 02:15 PM
Camshaft (rear half)
Attached image(s) |
bondo |
Jul 26 2004, 02:16 PM
Cylinder:
Attached image(s) |
bondo |
Jul 26 2004, 02:17 PM
Cylinder part number:
Attached image(s) |
bondo |
Jul 26 2004, 02:18 PM
Head:
Attached image(s) |
bondo |
Jul 26 2004, 02:19 PM
Piston underside (Mahle... is the good?)
Attached image(s) |
bondo |
Jul 26 2004, 02:21 PM
Last one for now..
piston top (anyone know an easy way to clean this? Carb cleaner doesn't touch it and a razor blade could scratch it) Attached image(s) |
SLITS |
Jul 26 2004, 04:49 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
"021" = 1.7
"022" = 1.8 "039" = 2.0 2.0 Bus heads have part #022 101 372G. Piston top - wire brush or glass bead blaster. Books say old screwdriver/ old compression ring - nothing sharp. Your piston better slide thru the barrel easily with no rings or you've got the wrong size. I can't find the piston to bore clearance figure. It also looks like a valve has touched the piston. |
bondo |
Jul 26 2004, 05:33 PM
I don't think it was a valve.. I cleaned that piston up, and there's that large dent, then a series of smaller dents all over it, and even some dents above the top ring on the sides. It looks like it ingested something and then pounded it to pieces... but I think that was prior to the rebuild because the cylinder and head look fine. Someone must have reused the piston.
Mark Henry |
Jul 26 2004, 05:36 PM
Looks like a 78-79 bus engine, late case, hydro lifters, small valve heads...maybe worth $500 as a core, probably less.
The heads need new seats. |
bondo |
Jul 26 2004, 05:53 PM
One head has that part number but without the G. (022 101 372) The Other head has no part number but on the outside has AML or AMC cast into it. The lifters are solid, and the case number is GD017555. It's beginning to look like this wasn't worth taking apart (IMG:style_emoticons/default/smile.gif)
Dave_Darling |
Jul 26 2004, 06:13 PM
914 Idiot Group: Members Posts: 14,986 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
AMC makes new castings of 1.7, 1.8, and Bus 2.0 heads. Sounds like the motor ate something, tore up the head and piston, and they re-ringed and honed the sucka and slapped a new ~$300 head on it.
--DD |
Korijo |
Jul 26 2004, 07:30 PM
[]D o [] o []V[] o []D Group: Members Posts: 1,308 Joined: 16-July 03 From: North Bend, WA Member No.: 914 |
If you end up parting it out, I'll take the rocker assemblies... OR...
just the 4 solid spacers between the rocker arms. (IMG:style_emoticons/default/biggrin.gif) lmk... |
Mark Henry |
Jul 26 2004, 10:21 PM
I was guessing at the hydro lifters...it's a hydro case, no pressure relief on the lifters. (IMG:style_emoticons/default/smile.gif)
Dave_Darling |
Jul 27 2004, 10:17 AM
Some 914 cases did not have that pressure relief either.
--DD |
Jake Raby |
Jul 27 2004, 10:52 AM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
That cam is hurtin'
SLITS |
Jul 27 2004, 10:58 AM
QUOTE(bondo @ Jul 26 2004, 04:53 PM) One head has that part number but without the G. (022 101 372) The Other head has no part number but on the outside has AML or AMC cast into it. The lifters are solid, and the case number is GD017555. It's beginning to look like this wasn't worth taking apart (IMG:style_emoticons/default/smile.gif) GD = '76 - '79 Bus (Type 2) |
Lo-Fi Version | Time is now: 20th May 2024 - 11:30 AM |
