> Cam Timing, Measuring
F4i
post Jul 29 2004, 06:55 PM
914 DOG!
Has anyone here actually measured thier cam timing? I have given it a rough go and found my results did not match the book. Intake 12 BT 42 AB Exh. 43 BB 4 AT is what the book says. I used a dial indicator on the valve itself. I may have the wrong cam. Please chime in engine builders. What actual results have people gotten?
Thanks 914 gang. (IMG:style_emoticons/default/beerchug.gif)
Brett W
post Jul 29 2004, 07:38 PM
What cam are you talking about? I did a cam not to long ago that went something like this:
Int opens 16deg BTDC
INt closes 48deg ABDC
Exh opens 52Deg BBDC
Exh Closes 20 Deg ATDC
F4i
post Jul 29 2004, 09:19 PM
914 DOG!
Sorry, You guys can't read my mind. Stock cam for a 2.0 4cyl.
J P Stein
post Jul 29 2004, 11:18 PM
Irrelevant old fart
Heh.....you'd love setting the cams (timing) on a 9eleben motor. (IMG:style_emoticons/default/blink.gif)
Jake Raby
post Jul 30 2004, 07:07 AM
Engine Surgeon
Try setting them on a 4 cam Carrera engine.... took me two days last time!
I really would not worry about it with a stock cam.....
F4i
post Jul 30 2004, 07:25 AM
914 DOG!
I am not sure it's a stock cam. Thats why I am asking. Things are not lining up. Motorcycles are no piece of cake either. It runs but I cannot get an idle without too much advance. Did a quick lift measurment with the help of Mark and think I may have a carb cam. .430 at the valve. I am going to check the duration and see what I have.
Mark Henry
post Jul 30 2004, 08:37 AM
that's what I do!
Dylan's getting .330 lift at the cam. I measured a new Web 73 and I get .320 lift
On the stock (used) cams I have I get about .275 at the cam, even less for a hydro.
It does have a rivet on gear and I’ve never heard of an aftermarket cam with a rivet on. (IMG:style_emoticons/default/huh.gif)
I’m at a total loss on this puppy. I’d hate to have Dylan rip out an OK cam, but things smell real fishy. (IMG:style_emoticons/default/unsure.gif)
- Lo-Fi Version Time is now: 30th July 2025 - 01:03 PM
