show me your battery cut-off install, best switch, location, etc |
Chris Pincetich |
Oct 21 2011, 02:03 PM
I like the battery cut-off switch that has a pre-cut mounting plate, but it has a red plastic handle. Are those plastic handles easily breakable??
Is the weatherproof/waterproof switch needed if I mount the switch directly over the battery in the small, side vent to the side of the engine lid? Best brand? Mounting location? Anything available w carbon fiber accents to match my 914? I have not seen carbon fiber bits on any of them and do plan to mount it in that side-space near the engine lid over the battery. This is for my cafe-racer cruiser that I AX with PCA and hope to take to the track some day. My 914 has a battery drain somewhere, I plan to track it down, but want to add the cut-off switch now as a band-aid (I currently disconnect the battery if it sits more than 48 hrs). I don't necessarily need SCCA compliance, and I do expect this to see daily driver type abuse. Thanks (IMG:style_emoticons/default/beerchug.gif) |
jhadler |
Oct 21 2011, 02:47 PM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
A battery cutoff is important safety equipment for w2w competition cars so corner workers can safely kill a running engine if the driver is incapacitated in a wreck. I would -not- recommend it for a daily driver though.
One: While they are generally robust, why would you add one more potential electrical failure point in your car? Trust me, I know a few folks who have missed getting their cars to grid because they couldn't diagnose the mysterious cause of their electrical failure when it was ultimately a loose connection in the kill switch. And this is a dedicated race car, with arguably more frequent maintenance than a street machine. Two: It would **REALLY** suck if some yahoo joker thought it would be cool to snag a nifty looking switch (especially if it's CF) off the car in a parking lot. They are deliberately made to be easy to pull... Granted, not all of them have a removable key/lever. But even still, any one could wander by and disconnect your battery... Just another example of what is good for the track is not necessarily good for the street... Just my $0.02... -Josh |
john rogers |
Oct 21 2011, 09:49 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
I added the switch on both our 914s in the small screen area on the drivers side. My mentor said he would get in the car, strap in and THEN remember to turn on the switch so he would get out, etc, etc, etc. With the bright red switch next to the driver's door it was harder to forget which I found was true. Driver's side.
Since the large battery wire runs to the starter anyways, it makes little difference in overall length of the wire. Finally, make sure to get the one with the large resistor so the alternator can be killed safely too. |
Chris Pincetich |
Oct 22 2011, 02:28 PM
Can an interior-mounted switch easily be wired to disconnect the battery from all systems?
With a kill switch over the battery, there is easy access to either power or ground cut-off options. |
campbellcj |
Oct 23 2011, 10:30 AM
I can't Re Member Group: Members Posts: 4,543 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
I have the switch directly over the battery in the side vent location as you mentioned. It's not optimal in terms of corner-worker accessibility but is far easier in terms of installation, and it's a very common install spot for 914's. I don't recall the brand (prob. OMP or Sparco) but mine is the multi-pole type with the alternator cutoff/protection circuit so it truly kills the car even when revving.
The plastic 'key' is not very fragile and on mine it's removable but mine is attached to the car via a cord/wire so I don't lose it. For a streetable car you could leave it removable to help prevent strangers from messing with it, and so it becomes nearly invisible. |
Racing916 |
Oct 25 2011, 06:11 AM
Member Group: Members Posts: 341 Joined: 16-October 04 From: Binghamton, NY Member No.: 2,959 Region Association: North East States |
Mine goes through the decoration grill on the driver side of the engine lid. It is reinforced in the back with a metal plate for strength.
Sorry for the lame shot, it is the only one I had with a picture of the cutoff!! Attached image(s) |
sean_v8_914 |
Oct 25 2011, 09:39 AM
small cable to the switch. missing sticker since I painted the 1/4 panel
Attached thumbnail(s) |
precisionchassis |
Oct 25 2011, 04:38 PM
Member Group: Members Posts: 99 Joined: 26-July 10 From: Gilbert, AZ Member No.: 11,979 Region Association: Southwest Region |
What happens if you have an engine fire? The red plastic will melt pretty fast at even moderate heat levels rendering the pull cable useless. Just sayin'...
sean_v8_914 |
Oct 25 2011, 07:30 PM
if it melts, it will open the circuit because the spring that holds it in contact will open
Oct 28 2011, 12:10 PM
Resident German Group: Admin Posts: 41,617 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Can an interior-mounted switch easily be wired to disconnect the battery from all systems? A interior mounted kill-switch defeats the purpose of the switch. The switch really isn't for you, it's for the guys on the outside trying to save your life while you're trapped inside a wrecked car. I haven't mounted mine yet (it's on the todo list) but here's what i got: https://www.pegasusautoracing.com/productde....asp?RecID=1464 The plastic handle is sturdy and removable so you can take it with you when you leave the car parked in public. (IMG:style_emoticons/default/shades.gif) |
Krieger |
Nov 25 2011, 01:12 PM
Advanced Member Group: Members Posts: 4,705 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I don't know exactly what your trying to do but you might consider adding an inertia activated fuel cut-off switch. I am going to put one of these on my track car. In a hard accident it effectively shuts off the fuel pump. Smart racing has one. I bet JEGS/Summit have them. About $60.
ConeDodger |
Nov 26 2011, 10:35 PM
Apex killer! Group: Members Posts: 23,575 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Check out Eric Shea's GT thread in the RoadGlue section or on Facebook if you are a friend. He mounted his in what I would assume is the traditional historic GT position. It is just forward of the windshield on the driver side cowl.
Eric's build is pretty true to authentic GT so I would assume that he mounted this in that spot because of authenticity. As Andy points out, it isn't for you, it is for the corner worker trying to save your ass and get you out. Attached image(s) |
stewteral |
Nov 27 2011, 12:52 AM
Old Member Group: Members Posts: 384 Joined: 4-December 07 From: Camarillo, CA Member No.: 8,424 Region Association: Southern California |
A battery cutoff is important safety equipment for w2w competition cars so corner workers can safely kill a running engine if the driver is incapacitated in a wreck. I would -not- recommend it for a daily driver though. One: While they are generally robust, why would you add one more potential electrical failure point in your car? Trust me, I know a few folks who have missed getting their cars to grid because they couldn't diagnose the mysterious cause of their electrical failure when it was ultimately a loose connection in the kill switch. And this is a dedicated race car, with arguably more frequent maintenance than a street machine. Two: It would **REALLY** suck if some yahoo joker thought it would be cool to snag a nifty looking switch (especially if it's CF) off the car in a parking lot. They are deliberately made to be easy to pull... Granted, not all of them have a removable key/lever. But even still, any one could wander by and disconnect your battery... Just another example of what is good for the track is not necessarily good for the street... Just my $0.02... -Josh Hey Josh, Rather than wiring a Kill Switch in hopes a minimum-wage corner-worker will be able to look for it and turn off all the electrics while I wait, hanging in my harness, hoping I'm NOT strapped in my own funeral pyre, I chose to install a FORD inertial cut-off switch. I mounted it to the right of the driver's seat on the inside of the engine firewall. If I should ever hit something hard enough, the shock-load kills the switch and all things electric in my car. A red button resets the switch in a second. I bought my switch some 8 years ago for around $15 and have run it on every track event. Even with a couple spins and ending up in the very rough desert off the track at Willow Springs, the switch has never tripped in error. I would suggest this switch as a good idea for ALL 914s to install in their cars. Best, Terry |
andys |
Nov 28 2011, 05:35 PM
I have a Ford inertia switch in my street 914/V8 car. Mine is wired to cut power to the fuel pump relay, but all other electronics will operate. The Ford switch has a normally open pin which allows it to be wired such that when the switch is tripped, a light on the dash will illuminate indicating it's been tripped.
Andys |
Bullethead |
Nov 29 2011, 05:14 PM
Oil Cooled heart Group: Members Posts: 895 Joined: 24-June 10 From: South Florida Member No.: 11,875 Region Association: South East States |
pcar916 |
Dec 11 2011, 07:13 PM
Sir Andy has a pic above that looks a bit like mine. Here is the underneath wiring mounted on the left cowl.
pcar916 |
Dec 13 2011, 10:38 AM
The plastic handle is sturdy and removable so you can take it with you when you leave the car parked in public. (IMG:style_emoticons/default/shades.gif) True that. And it's prudent to have one in the glove box as well. Take my word for it, buy a spare. (IMG:style_emoticons/default/beerchug.gif) p.s. The resistor dumps the residual juice to ground to save your electronics. If you don't have any a standard switch will do. |
mr914 |
Oct 23 2012, 08:52 PM
914 Hillbilly Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None |
Anybody have a schematic for a 6?
Of course, one side breaks ground. But the other side & resistor? Cuts off the pos or neg side of the coil? (IMG:style_emoticons/default/headbang.gif) Never done one in my 30+ years.... |
pcar916 |
Oct 24 2012, 09:29 AM
The resistor allows a gentle dump-to-ground that reduces the "shock" to the car's electronics (DME or any other electronic ignition system and the voltage regulator) when the power is cut off abruptly. It can't hurt you in any case to install one.
Wiring with resistor: https://www.pegasusautoracing.com/pdfs/4430...nstructions.pdf All of the racing outfits have them, Racer Wholesale Parts, Pegasus, Summit, etc. Good luck |
ChrisFoley |
Oct 25 2012, 10:41 AM
I am Tangerine Racing Group: Members Posts: 7,922 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I installed the one for my race car inside the passenger compartment.
The one on my street car is mounted to a solid panel which replaces the grille over the battery. |
Lo-Fi Version | Time is now: 4th May 2024 - 04:11 PM |
