machina |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 ![]() ![]() |
Little job like fabricating a bracket took entire weekend, well whatever time I had to work on the car. Maybe 5 hours.
I really hacked up the bracket. Couldn't find the right tool to cut the inside of the aluminum. Tried fine tooth saber, cutoff wheels, dremel cutoff, snips, What work best for cutting aluminum? Then, since I put the gauges in fastened from behind, it was a major bitch to got the mounting nuts on for the bracket behind the dash. Going to try some nut plates next. Anyway, looks like I wanted it to. Always thought about putting gauges in this spot since I removed the ashtray. Then I saw on the rennsport reunion that the 911 that ran the targa florio had a couple gauges in the same spot, so it can't be too bad of an idea. dr Attached image(s) ![]() |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
QUOTE(synthesisdv @ Aug 1 2004, 11:15 AM) What work best for cutting aluminum? air nibbler |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,542 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
dremel spiral saw bits (IMG:style_emoticons/default/wink.gif) work great!
Carrera916 |
Member ![]() ![]() Group: Members Posts: 292 Joined: 9-February 03 From: Pleasanton, CA Member No.: 273 ![]() |
dr,
could you post a close up picture of the gauge iself? It looked interesting and who makes them? Where did you find them? I might be interested in it... thanks, jerry |
machina |
QUOTE(Carrera916 @ Aug 1 2004, 03:50 PM) dr, could you post a close up picture of the gauge iself? It looked interesting and who makes them? Where did you find them? I might be interested in it... thanks, jerry Westach, Makes all types of instruments for aviation to tractors. Their site shows it all. dr http://www.frostalarm.com/cat/hindex.html Attached image(s) ![]() |
Carrera916 |
Thanks!
j |
MXMARK |
Member ![]() ![]() Group: Members Posts: 205 Joined: 15-February 04 From: Riverside, Ca. the new (951) Member No.: 1,656 ![]() |
That looks cool, I have my cht and fuel gauge in a vdo bracket in that spot. Yours looks great.
I wonder if they wood fit in my vdo bracket? Thanks Mark Attached image(s) ![]() |
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
hmmmm.... gauges
Lo-Fi Version | Time is now: 17th July 2025 - 07:37 PM |
