> Pierburg Fuel Pump, What does it fit?
JawjaPorsche
post Oct 28 2011, 02:22 PM
I was going through my stuff this morning and I found a new fuel pump someone gave me a long time ago. I went online to try to find what it fits but the pump has no markings except for the name "Pierburg."
Are there any Pierburg experts out there that might point me in the right direction?
Pictures attached. Thank you in advance.
Terry
bandjoey
post Oct 28 2011, 03:08 PM
bandjoey
A rotary pump for carbs? What's the mod #?
Cap'n Krusty
post Oct 28 2011, 03:10 PM
Cap'n Krusty
Pierburg makes a wide range of pumps in different pressure and volume specifications. Might wanna slip off the insulation and see if there are any identifying marks on the body of the pump.
The Cap'n
JawjaPorsche
post Oct 28 2011, 03:22 PM
Hi Cap'n
You are much smarter than me! Why didn't I think of that!
I removed the insulation and there is markings on the pump!
99T183 and 7.21565.00
Does anyone know what these markings mean?
Terry
QUOTE(Cap'n Krusty @ Oct 28 2011, 05:10 PM) *
The Cap'n
SLITS
post Oct 28 2011, 04:14 PM
"This Utah shit is HARSH!"
It's a "universal fit" pump, but the pressure output is suited to /6 CIS systems.
SPECS:
EXTERNAL FUEL PUMP
150 LPH @ 5BAR
INLET CONNECTION 15mm(1/2)
OUTLET CONNECTION M12X1.5
LENGTH: 200 mm
DIAMETER: 42 mm or 60 mm (with rubber sleeve)
MAX POWER/Cons(Amps): 10
CROSS REF:
BOSCH: #0580464070, #0580464008, #058046491
All you need to add is the check valve fitting at the outlet end.
JawjaPorsche
post Oct 28 2011, 04:20 PM
Wow, thanks Slits.
You really know your fuel pumps!
Thank you so much.
Terry
QUOTE(SLITS @ Oct 28 2011, 06:14 PM) *
SPECS:
EXTERNAL FUEL PUMP
150 LPH @ 5BAR
LENGTH: 200 mm
CROSS REF:
jcd914
post Oct 28 2011, 06:15 PM
Specs are straight out of an e-bay ad that comes up on a google search for "Pierburg 7.21565.00"
google is your friend
bandjoey
post Oct 28 2011, 06:18 PM
bandjoey
CAn someone translate 150 LPH @ 5BAR
into normal language...like FI needs 30 pounds of pressure for example???
Cap'n Krusty
post Oct 28 2011, 07:18 PM
Cap'n Krusty
One BAR equals 14.5 PSI, more or less. 5 BAR is about 72.5PSI. Again, Google is your friend. CIS FI (K-jetronic) runs at that kind of pressure.
The Cap'n
- Lo-Fi Version Time is now: 11th March 2026 - 01:44 AM
