Aftermarket shoulder harness bar for early 914, Installation of harness bar in 70 914 |
6fahrer |
Aug 2 2004, 10:14 AM
Der Grosse 914 Auf-Fahrter Group: Members Posts: 27 Joined: 6-July 04 From: Sacramento, CA Member No.: 2,311 |
(IMG:style_emoticons/default/huh.gif) I have a 1970 914-6 that I ordered an aftermarket seat harness bar for, only to discover that the early 'fixed passenger seat' interior back pad used in 1970-71 914s will not allow use of such a bar, unless the headrest of the immobile passenger seat is cut-off ( (IMG:style_emoticons/default/sad.gif) ) or removed altogether.
Despite being able to determine this to be a potential problem in advance of the fact (by checking the bar attachment points against the existing interior fittings), like a dunce I did not do so. Hence the bar arrived from Performance Parts (they state the bar is suitable for use in 1970 through 76 914 models, but neglect to further advise that the passenger seat prevents installation unless removed beforehand. I am not necessarily put off by 'decapitating' the passenger seat headrest in my car, so as to allow use of the bar, but it still bothers me to contemplate screwing up an early style 914's interior in this rather forceful (and irrepairable) manner. Again, suggestions would be appreciation if you have encountered a similar frustration (IMG:style_emoticons/default/blink.gif) . Cheers, 6Fahrer |
ArtechnikA |
Aug 2 2004, 10:31 AM
pull the backpad and store it safely. find a passenger seat from a 73+. find some nice black vinyl or Perlon to cover the firewall, if you are so inclined.
Joe Ricard |
Aug 2 2004, 10:51 AM
I too have this problem. I am thinking of cutting out a section of the head rest to fit around the bar. My Early needs to be recovered anyway. The other option is to put some dynamat and grey / black carpet. Those fire walls without sound insulation are Loud. Sort of like a huge sub woofer this a type IV motor as the amp.
Aug 2 2004, 01:12 PM
Resident German Group: Admin Posts: 41,607 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
(IMG:style_emoticons/default/agree.gif) with rich. remove the backpad and get a later, moveable seat with rails and be done with it.
there's a easy and a not so easy way to mount the moveable seat to a early car: - right way to do it (not so easy) get the floor hinges and weld them to the floorboard. get the up/down adjuster bracket and weld it to the crossbar. then mount seat rails on that. - the *not so* right way to do it (much easier) take the rails and bolt them directly to the floor using the existing (no-moveable) hinges in the back. the rails will fit perfectly. bolt them down in the front using the already threaded holes "on top" of the crossbar. again, perfect fit. the seat rail will be in a fairly "up" position and you can't adjust up/down but other than that it works great. front/back adjustement works just like expected. (IMG:style_emoticons/default/smile.gif) Andy |
Joe Ricard |
Aug 2 2004, 06:06 PM
Never did like passengers in my car anyway. They just distract me. Wife already said she will NEVER ride in my car with me again anyway. (IMG:style_emoticons/default/idea.gif)
ArtechnikA |
Aug 2 2004, 06:40 PM
QUOTE(Joe Ricard @ Aug 2 2004, 04:06 PM) Never did like passengers in my car anyway. They just distract me. in some Regions, a DE car has to have a seat for an instructor... |
Lo-Fi Version | Time is now: 30th April 2024 - 12:57 AM |
