front air dam, correct ride height? |
Trekkor |
Aug 3 2004, 12:00 AM
I'm setting up a custom rubber flex dam off an LE F/G dam.
I want the clearance to be the ABSOLUTE minimum. How much room should I allow? Can't limbo under my dam. (IMG:style_emoticons/default/jester.gif) Flexy T |
Brad Roberts |
Aug 3 2004, 12:02 AM
Enough so cooling air passes under the car....
Leave at least 2 inches. B |
Trekkor |
Aug 3 2004, 12:07 AM
Thanks, Brad . Thats exactly the amount I had in mind.
McMark |
Aug 3 2004, 12:08 AM
I was right about the cooling air. (IMG:style_emoticons/default/monkeydance.gif)
Brad Roberts |
Aug 3 2004, 12:11 AM
Rob Way's car tends to overheat..... so dose Darren Dowds..... everyone who runs the flexdam.
B |
Trekkor |
Aug 3 2004, 12:15 AM
I cleaned my oil cooler, so now I'm good to go...Bro!
Coolious Teaser |
Joe Ricard |
Aug 3 2004, 06:05 AM
Air must run underneath the car why? Is there some sort of scavenging effect pulling air out of the engine? HMMMM now I think I may have been killing myself when I drove the car home with that really low "cow catcher dam" I could get my toe under it in running shoes. Sure made the car stick to the road.
McMark |
Aug 3 2004, 08:30 AM
There is a certain amount of oil cooling that goes on when the oil is at the bottom of the engine. There's a reason Porsche added the two "air flaps" on the front lip of the engine bay in 1973. Those two guys stir up the air to create turbulence and get more air up around the engine and cool it.
Joe Ricard |
Aug 3 2004, 08:45 AM
DAng now I will have to re-evaluate the idea I was mulling over in my head. I wanted to make an under belly pan like 928 and some later 911 cars. Thought of louvers to let engine air escape. and now thinking NACA ducts to get some air blowing past the bottom of the motor.
I want the pan to go from the front edge of the fire wall to at least the engine mount bar. |
maf914 |
Aug 3 2004, 11:51 AM
QUOTE(markd@mac.com @ Aug 3 2004, 06:30 AM) There's a reason Porsche added the two "air flaps" on the front lip of the engine bay in 1973. Those two guys stir up the air to create turbulence and get more air up around the engine and cool it. There are a lot of opinions about the two flaps Porsche added. I don't think they are there to create turbulence, but are there to direct the airlow from the floor pan down and away from the areas under the cylinders and heads, creating a low pressure area that lets the pressurized cooling air from the cooling fan and shroud exit from the cylinders and heads more easily. The fact that they didn't use a single flap across the engine bay makes me wonder if they wanted some airflow across the finned bottom of the sump. I don't know how much cooling occurs at the sump. It seems it would be relatively small. I've also wondered about the effects front spoilers have on 914 cooling. I still think someone needs to get a 914 into a full scale rolling road wind tunnel and test out all of our theories! (IMG:style_emoticons/default/laugh.gif) |
maf914 |
Aug 3 2004, 11:55 AM
QUOTE(Joe Ricard @ Aug 3 2004, 06:45 AM) DAng now I will have to re-evaluate the idea I was mulling over in my head. I wanted to make an under belly pan like 928 and some later 911 cars. Thought of louvers to let engine air escape. and now thinking NACA ducts to get some air blowing past the bottom of the motor. I want the pan to go from the front edge of the fire wall to at least the engine mount bar. Joe, The belly pan sounds interesting. You may have already seen these but check the project cars gallery at Patrick Motorsports. Some of them appear to have full pans at the rear. http://www.patrickmotorsports.com/cgi-bin/...?action=gallery I remember reading about the 956/962 cars in the 80's. During qualifying the teams used to block off the louvers that exhausted engine heat into the underbody venturi's to increase downforce. They could only do this for a few laps before the temps would rise too much. |
machina |
QUOTE(maf914 @ Aug 3 2004, 01:51 PM) I still think someone needs to get a 914 into a full scale rolling road wind tunnel and test out all of out theories As soon as a team decides to run one in NASCAR, otherwise its all trial and error. dr |
Aug 3 2004, 11:58 AM
Resident German Group: Admin Posts: 41,607 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
ok, here's another one ...
how about two air-scoops under the car, right next to the "flaps" that direct fresh cold air UP and directly into the intake? that should work nicely, right? (IMG:style_emoticons/default/idea.gif) Andy |
machina |
Aug 3 2004, 12:02 PM
QUOTE(SirAndy @ Aug 3 2004, 01:58 PM) how about two air-scoops under the car, right next to the "flaps" that direct fresh cold air UP and directly into the intake it will also scoop up every rock and pile of dirt that gets too close, better not go off. dr |
maf914 |
Aug 3 2004, 12:07 PM
QUOTE(SirAndy @ Aug 3 2004, 09:58 AM) ok, here's another one ... how about two air-scoops under the car, right next to the "flaps" that direct fresh cold air UP and directly into the intake? that should work nicely, right? (IMG:style_emoticons/default/idea.gif) Andy In the winter that would be cool, but in the summer the air temperature at the suface of the road is what... 130-140 degrees? (IMG:style_emoticons/default/laugh.gif) Well, maybe not in California, but it gets hot as a mofo in Georgia. (IMG:style_emoticons/default/laugh.gif) |
Aug 3 2004, 12:14 PM
QUOTE(synthesisdv @ Aug 3 2004, 11:02 AM) it will also scoop up every rock and pile of dirt that gets too close, better not go off. of course with a good air-filter in line, you could build it in a way that rocks etc. just bounce off the air-filter and fall back down. QUOTE but in the summer the air temperature at the suface of the road is what... 130-140 degrees? now that is a good point ... (IMG:style_emoticons/default/idea.gif) still thinking (IMG:style_emoticons/default/idea.gif) Andy |
SpecialK |
Aug 3 2004, 12:37 PM
aircraft surgeon Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 |
If you wanted some more cooling air going to the engine compartment, I think I'd go with side scoops (NACA) right behind the doors, and duct them through the fender wells into the engine compartment. Hell, you could even flex pipe it right to the fan inlet. Debris would be kept to a minimum even with the occasional "off-road" excursion. (IMG:style_emoticons/default/wink.gif)
I'm working on ducting my "Old school Trans-Am front fender vents" (mounted backwards a few inches behind the doors) to each of the Webers. I still need to figure out a system (bicycle brake cables?) to open/close them in conjunction with the heater flapper valves. I figure if it's too cold for me, it's too cold for the carbs by my calculations [1970 Baja Bug+Holley Bugspray Carb+New Mexico in December=Ice Maker]. (IMG:style_emoticons/default/biggrin.gif) |
Joe Ricard |
Aug 3 2004, 07:31 PM
Cold air = more horse power. just don't run the big plastic spacer inbetween the head and manifold. should keep carb from freezing. oh hell what do I know I live in Mississippi, I'm half hammered and it's my birthday. (IMG:style_emoticons/default/beer.gif)
Need bigger piece of aluminum sheet to span the area I want to cover. (IMG:style_emoticons/default/smash.gif) I like think bending the trailing edge down a bit should create a void in the air stream to allow heat engine cooling air to be sucked out and expelled. |
Andyrew |
Aug 3 2004, 08:12 PM
Honestly, I hate the flexidam... I took off the flexible part, and Boy do I like it!
Too bad I need some air flow with the radiator.. 916 comin my way... Andrew Word to all those with flexidams.. |
Air_Cooled_Nut |
Aug 3 2004, 09:10 PM
914 Ronin - 914 owner who lost his 914club.com Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
[QUOTE=maf914,Aug 3 2004, 09:55 AM] [QUOTE=Joe Ricard,Aug 3 2004, 06:45 AM]
Joe, The belly pan sounds interesting. You may have already seen these but check the project cars gallery at Patrick Motorsports. Some of them appear to have full pans at the rear. http://www.patrickmotorsports.com/cgi-bin/...?action=gallery I remember reading about the 956/962 cars in the 80's. During qualifying the teams used to block off the louvers that exhausted engine heat into the underbody venturi's to increase downforce. They could only do this for a few laps before the temps would rise too much. [/QUOTE] That web site shur has some pretty pictures... Have no idea what that DME thang is they're touting but I found this picture the most informative: (IMG:http://www.patrickmotorsports.com/img/gallery/884.jpg) Now I know the orientation and position of that part I need to [eventually] replace, where the swing arm mounts (is that the console?). It's nice to have a picture of what something should look like. |
Lo-Fi Version | Time is now: 29th April 2024 - 09:04 PM |
