stupid human questions, electrical stuff |
machina |
Aug 3 2004, 04:35 AM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
Need to wire new gauges, old gauges, fuel pump, ignition, etc.
Do I run new wires for all of the above? Don't need many circuits, its a racecar. Also, we don't run an alternator now, so where do all the wires go that were connected to it? Sorry but I've never wired up anything more that a set of foglights before. Thanks, dr |
Joe Ricard |
Aug 3 2004, 08:15 AM
It should be just a matter of positive and negative / ground. The Alt cable can be deleted as well as voltage regulator. Run everything to the relay panel in Engine compartment from a new lead on battery. The power cable to the fuse panel should remain the same.
Lo-Fi Version | Time is now: 17th May 2024 - 09:40 AM |
