Drivers door handle, I am a little upset |
Aaron Cox |
Apr 26 2003, 01:57 PM
i won a set of door andles off the bay the other day. to replace my drivers door handle that broke (cracked and was floating around on the shaft!) and i take my door panels off (what a joy that is (IMG:style_emoticons/default/cool.gif) ) and i go to install the new door handle- and it has a small crack that is in THE EXACT SAME SPOT!!!!!! (IMG:style_emoticons/default/mad.gif) im not going to install a doorhandle that is about to break!!!!!
so my question is: "does anyone have a DRIVERS doorhandle that they would like to trade for a passeger doorhandle or even 2 passenger doorhandles?" |
Porsche Rescue |
Apr 26 2003, 02:12 PM
I believe the door handles are interchangeable. The only diffference is the shape of the corners, hardly noticeable.
Joe Bob |
Apr 26 2003, 02:14 PM
They ARE interchangeable.....but they are different, look close at the bottom. It is curved while the top is more of a 90 degree angle....
I have two marked "R" on the inside flap, BTW.....I believe they are the driver's side. |
Joe Bob |
Apr 26 2003, 02:19 PM
See, these are both "R"....
Joe Bob |
Crap....here is tis
URY914 |
Apr 26 2003, 02:25 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 119,642 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I can fix the broken one if you want to send it to me.
need4speed |
Apr 26 2003, 06:03 PM
Member Group: Members Posts: 339 Joined: 11-April 03 From: Arroyo Grande, CA Member No.: 564 |
situations like these are why the good Lord invented JBWeld.
no? (IMG:style_emoticons/default/aktion035.gif) |
Aaron Cox |
Apr 26 2003, 06:42 PM
In the mean time, i'm using my spare "R" as my drivers one. Ill send the goods back to the ebayer and ask for a new set or a refund.
QUOTE I can fix the broken one if you want to send it to me. HOW? welding? would epoxy work ? QUOTE situations like these are why the good Lord invented JBWeld. Is that similar to epoxy? |
URY914 |
Apr 26 2003, 07:30 PM
JB Weld won't fix it. I made two pieces of aluminum angle which fit in place of the bushings and act as a new and stronger mounting base.
Aaron Cox |
Apr 27 2003, 12:25 PM
QUOTE(URY914 @ Apr 26 2003, 05:30 PM) JB Weld won't fix it. I made two pieces of aluminum angle which fit in place of the bushings and act as a new and stronger mounting base. whats it gonna cost me t' get it fixed? (IMG:style_emoticons/default/biggrin.gif) |
Lawrence |
Apr 27 2003, 05:59 PM
That mod is really cool. Curious, how long does it take you to repair one? Does it fit exactly into the old place with no changes to the door?
-Rusty |
URY914 |
Apr 27 2003, 07:39 PM
It takes a couple of hours to fix one. I charge $75.00 which includes shipping. If you want the plastic piece changed at the same time you buy it (Tweeks and Performance Products have them) and send it to me with the handle and I'll put it on at no addtional charge. (IMG:style_emoticons/default/biggrin.gif)
Send me an email if you want to do it and I'll give you my address. Paul (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 29th March 2024 - 07:39 AM |
