Seat Rail restoration, Has anyone taken one apart |
LotusJoe |
Nov 9 2011, 03:28 PM
Europa Twink Driver Group: Members Posts: 406 Joined: 30-November 09 From: Southern California Member No.: 11,085 Region Association: Southern California |
I'm thinking about taking the seat rails apart to have them powder coated and fresh zinc plating done on the hardware. Has anyone taken one apart? It looks like a knuckle buster. Tricks to getting them apart and back together again? (IMG:style_emoticons/default/confused24.gif)
Thanks Joe |
McMark |
Nov 9 2011, 05:17 PM
I haven't taken one apart, but oddly enough, it's on the schedule for later this month. One word of warning, powdercoating will likely be too think on the sections where the seat rail actually slides. I was planning on masking those four strips, top and bottom. I even thought of polishing those areas for better slide action...
Phoenix-MN |
Nov 9 2011, 05:19 PM
Senior Member Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
I'm thinking about taking the seat rails apart to have them powder coated and fresh zinc plating done on the hardware. Has anyone taken one apart? It looks like a knuckle buster. Tricks to getting them apart and back together again? (IMG:style_emoticons/default/confused24.gif) Thanks Joe "Piece-O-cake" I did mine without any problems. Here's some pictures from my site http://phoenixhobbies.com/html/interior.html Paul |
Harpo |
Nov 9 2011, 05:25 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Very nice, please tell us how you got that spring off
David |
LotusJoe |
Nov 9 2011, 05:30 PM
I'm thinking about taking the seat rails apart to have them powder coated and fresh zinc plating done on the hardware. Has anyone taken one apart? It looks like a knuckle buster. Tricks to getting them apart and back together again? (IMG:style_emoticons/default/confused24.gif) Thanks Joe "Piece-O-cake" I did mine without any problems. Here's some pictures from my site http://phoenixhobbies.com/html/interior.html Paul Thanks Paul, I see you also put a boxster exhaust on your car. I'm doing the same thing; do you have any additional pictures of the brackets and such? Regards Joe |
Phoenix-MN |
Nov 9 2011, 06:58 PM
Phoenix-MN |
Nov 9 2011, 07:00 PM
[/quote] Thanks Paul, I see you also put a boxster exhaust on your car. I'm doing the same thing; do you have any additional pictures of the brackets and such? Regards Joe [/quote] Sent a PM |
ellisor3 |
Nov 9 2011, 07:56 PM
HPWhore Group: Members Posts: 811 Joined: 23-October 08 From: Fleming Island, Florida Member No.: 9,683 Region Association: South East States |
I did mine as well and had them powder coated. Do Not let them powdercoat the slides on either side. I spent hours grinding it back off, and reassembling the rails to see if they would work. One of the worst mistakes I made on my whole project. I would simply have the exterior done and simply put some rust prevenative on the slides themselves.
ellisor3 |
Nov 9 2011, 08:00 PM
Very nice, please tell us how you got that spring off David If you take a pair of needle nose vice grips and attach them to the side of the spring simply to hold it, you can the use a screw driver to remove the spring without having it go flying. This will also work in the reverse to get it back on. It is tough but doable. |
nsr-jamie |
Nov 10 2011, 06:25 AM
914 guy in Japan Group: Members Posts: 1,182 Joined: 7-November 07 From: Nagoya, Japan Member No.: 8,305 Region Association: None |
Its pretty easy, I did it this summer while my car was in the shop...the hardest part for me was trying to remove the bolts that held the rail to the bottom of the seat. Two stripped out on me and it was a big pain to fix but finally did it and than I sand blasted them and sprayed them which I think was not the best thing to do as it is very tight and hard to adjust the passenger seat now, the drivers side moves alright..I also greased up the rails too and that helped a bit and installed the new adjuster handles from 914 rubber.com while I was at it.
LotusJoe |
Dec 9 2011, 06:43 PM
I'm thinking about taking the seat rails apart to have them powder coated and fresh zinc plating done on the hardware. Has anyone taken one apart? It looks like a knuckle buster. Tricks to getting them apart and back together again? (IMG:style_emoticons/default/confused24.gif) Thanks Joe "Piece-O-cake" I did mine without any problems. Here's some pictures from my site http://phoenixhobbies.com/html/interior.html Paul Paul, you were exactly correct. the seat rails went back together much easier than I thought. Took about 20 minutes to get everything back together and installed in the car. Had the rails powder coated, the handles nickel plated, and rest of the bits yellow zinc. I know it's a bit of over kill on parts you'll never see, but at least it should keep the corrosion at bay for a period and time. Thanks for the encouragement. |
zymurgist |
Dec 10 2011, 09:05 AM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
Very nice looking job! I just had this stuff apart last weekend and it doesn't look nearly as good.
Dec 10 2011, 09:48 AM
Funny,
I took a set apart thinking I had to restore them to get a good set. Sandblasted..cleaned, painted, new grease... I was very proud. I found a mint OEM set in the storage about three months later that I had taken off to save for future use. Sucks getting old. Rich |
Lou W |
Dec 10 2011, 02:11 PM
"Here Kitty Kitty" my ass...... Group: Members Posts: 4,109 Joined: 9-May 04 From: Roseburg, OR. Member No.: 2,039 Region Association: Spain |
Funny, I took a set apart thinking I had to restore them to get a good set. Sandblasted..cleaned, painted, new grease... I was very proud. I found a mint OEM set in the storage about three months later that I had taken off to save for future use. Sucks getting old. Rich That's funny, something I would have done. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 08:58 PM |
